01-29-2014, 05:19 PM
eugene
, Oregon
Wiring powermax boondocker converter
I purchased a powermax converter from Randy at Best converters.
It requires an outlet to plug into. I have a 23' 2006. There is no outlet in the converter area under the wardrobe. How did others do this?
If one was to want to install a plug in in that area what wire would you tap into?
Greg
01-31-2014, 05:54 AM
1995 30' Excella
Bowie
, Maryland
How was the old converter wired?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
01-31-2014, 07:02 AM
1966 22' Safari
Hilltop Lakes
Ours is a much older trailer, so this might not apply…
We took the wire that powered the original univolt and ran it to a new outlet (surface mount box ) mounted on the inner wall near the converter location. Just be sure your connections are correct and that all exposed wiring is contained in a covered box. Everything we needed was readily available at the big box stores.
02-04-2014, 09:30 PM
eugene
, Oregon
Wiring
I disconnected and removed the old converter. There was a + blue wire and - white wire from the old converter. It was easy to connect the new converter to those connections.
However there was a black wire that ran from a circuit breaker to the old converter and a white wire that ran from just left of the breaker (connected to a vertical silver bar with several connectors) to the converter. Both of these wires had slip type connectors at the old converter. I'm not sure what these do?
02-04-2014, 09:42 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
They are the 120v ac power supply for the converter. Connect them to a surface mounted box and inatall a receptacle. It should have a bare ground wire also.
Dan
02-05-2014, 05:42 PM
eugene
, Oregon
Thanks Dan.
I am thinking the black wire from the breaker is the hot, the white wire from the vertical bar is the neutral and the horizontal bar is for the ground. Is that right?
02-05-2014, 06:25 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
You are correct. Connect the hot black wire to the right side of the receptacle (gold screw) the neutral white wire to the left side (silver screw) and the bare ground wire to the ground terminal. Install the cover and plug your new converter in. Easy peasy.
Dan
03-14-2014, 09:13 AM
eugene
, Oregon
To Anyone that installed a power max boondocker.
Did you wire the chassis bonding lug to the frame or just ignore it?
Thanks.
03-14-2014, 09:29 AM
Summerville
, South Carolina
I used a standard 120v female extension cord receptacle wired to the panel using a black hot wire and a white neutral wire. I also bonded all grounds together. Then just plugged the converter into the receptacle. I will try to post a picture. You can see the yellow receptacle on the right.
03-14-2014, 09:32 AM
Summerville
, South Carolina
It looks like my picture was not uploaded on the last posting. Let me try again.
03-14-2014, 09:35 AM
Summerville
, South Carolina
See if this works
03-14-2014, 03:12 PM
eugene
, Oregon
Hank,
Thanks for the post. So you ran a wire from the chassis bonding lug to the bar that holds all the ground wires?
03-15-2014, 08:11 AM
Summerville
, South Carolina
Yes, all grounds were bonded together. This is important for electrical safety.
03-15-2014, 08:46 AM
Summerville
, South Carolina
Cya,
If you send me a PM with your email address I will send you all the pictures I have of my installation.
04-09-2014, 04:40 AM
2020 16' Nest
Saint Augustine
HasAnyone put a separate heat sensor one there upgrade? The only one I see that has one is the xantrex charger. I need to replace my convertor.
11-09-2016, 03:05 PM
1974 27' Overlander
Beaver
, Pennsylvania
Chassis Ground on Boondocker
Should I run a ground wire from the chassis ground on the Boondocker to the bus on the fuse box where the other ground and the black wire from batteries are connected?
Currently on my fuse box bus I have: black wire from battery, black wire from Boondocker, white ground to frame
Or, should I run a whole new ground wire to the frame from the chassis ground on the Boondocker?
