Old 04-09-2014, 05:40 AM   #15
Coaster's Avatar
Saint Augustine , Florida
HasAnyone put a separate heat sensor one there upgrade? The only one I see that has one is the xantrex charger. I need to replace my convertor.
Coaster is offline   Reply With Quote
Old 11-09-2016, 04:05 PM   #16
1974 27' Overlander
Beaver , Pennsylvania
Chassis Ground on Boondocker
Originally Posted by Captain Hank View Post
Yes, all grounds were bonded together. This is important for electrical safety.
Should I run a ground wire from the chassis ground on the Boondocker to the bus on the fuse box where the other ground and the black wire from batteries are connected?
Currently on my fuse box bus I have: black wire from battery, black wire from Boondocker, white ground to frame
Or, should I run a whole new ground wire to the frame from the chassis ground on the Boondocker?
crnjarich is offline   Reply With Quote
Univolt to Powermax Boondocker and FB-9 control panel on 1972 Ambassador davidlaxson Batteries, Univolts, Converters & Inverters 6 06-17-2012 05:53 PM
Univolt to Powermax boondocker with new FB-9 circuit panel davidlaxson Electrical - Systems, Generators, Batteries & Solar 0 01-24-2012 09:08 PM
Powermax converter with Parallax fuse block Flynavy Batteries, Univolts, Converters & Inverters 4 09-03-2011 04:44 AM
Intellipower Converter wlanford Batteries, Univolts, Converters & Inverters 24 07-21-2011 11:27 PM
