Old 11-13-2013, 04:01 PM   #1
Aptos , California
Wiring new intellipower
Hi all,
So there are three wires from the univolt
blue for battery pos.
white for battery neg.
and red for battery load positive.
But there are only two places on the new intellipower converter.
One positive and one neg.
so do both positive wires go on the new positive or am I supposed to do something more complex?
farmerdave is offline   Reply With Quote
Old 11-13-2013, 04:14 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Firstly, you should know I aint no electrician.
My guess is the white wire is your nuetral feed into a buss bar for your fuse panel. The red to the positive side. So blue should go to your - battery terminal and red +. But wait until someone else confirms this. I would call Randy at Best Converter. There should also be a ground for the Intellipower.
Old 11-14-2013, 08:06 AM   #3
Aptos , California
Any electricians out there?
Old 11-14-2013, 08:24 AM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Sounds like we are talking about your 12 volt system. White wire should be your ground. The other two wires should be power leading out. Possibly one to the battery and one to your 12 volt fuse panel. When I installed my intipower converter I called to see how the battery should be hooked up. The stated that the battery can be any where on the system, or you can run one of your two power leads to the battery (if you have two) and the other to your 12 vlt fuse panel.
Can you trace the two wires? I'm thinking like you one feeds the battery and the other feeds the panel.
Silverflames is offline   Reply With Quote
Old 11-14-2013, 09:42 AM   #5
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Isn't blue supposed to be the charge line from the TV?
robwok is offline   Reply With Quote
Old 11-14-2013, 10:21 AM   #6
1969 29' Ambassador
Seems odd that it would go to the inverter and not the 12 volt fuse panel. Possible I guess.
Old 11-14-2013, 10:50 AM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
In the photo the blue wire looks like a heavy gauge wire, maybe 8 or 6. Blue is usually the charge line from the tow vehicle, and is heavier than the other wires, but I think it is no heavier than a 10 gauge. Could be wrong.
Old 11-14-2013, 03:28 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would guess that the blue and red wires on the left in your first photo go to the glass fuses above. One to each fuse.
You could use an AGU 2 position fuse block and wire it similar to the drawing below. bring the red and blue wires in on the left side, then run a single wire from the right side to the + on the converter.
http://i1166.photobucket.com/albums/...rconverter.jpg
http://i1166.photobucket.com/albums/...k2position.jpg
The white wire is not NEUTRAL; it is common/ground.
TG Twinkie is online now   Reply With Quote
Old 11-14-2013, 07:45 PM   #9
SkooterPop's Avatar
1973 Argosy 26
Chandler , Arizona
I believe the blue wire is the charge line to and from the TV, so that would be attached to one of the fused outgoing lines with a 30 Amp fuse, if I am not mistaken. So, red from or to battery positive, white to battery negative or ground elsewhere, and blue to fuse panel with 30 Amp fuse. I would recommend you get more expert advice but that is my humble opinion.
“The whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by an endless series of hobgoblins, most of them imaginary.”
H.L. Mencken
SkooterPop is offline   Reply With Quote
Old 11-14-2013, 08:27 PM   #10
1969 29' Ambassador
Hey look!! There is a wiring diagram behind the wires!! Can you move the wires and get a better pic of it?
Old 11-14-2013, 09:59 PM   #11
Aptos , California
Better picture of the diagram
Old 11-14-2013, 10:38 PM   #12
1969 29' Ambassador
Ok, starting at the bottom. I like bottoms... That appears to be your 110 volt AC shore line power. You will need to put some kind of female 110 volt AC plug on those wires to plug into your new inverter. Black should be hot, white common, the striped copper ground. Plz correct me if I'm wrong.
Blue wire. + battery
White wire. - battery
Dirty looking ?? Wire (load). What I would consider to your 12 volt DC fuse panel. Of any other 12volt DC power draw.
Do you have a 12 volt DC fuse panel?
Old 11-14-2013, 10:45 PM   #13
Aptos , California
Yes there is a fuse panel.
Old 11-14-2013, 10:53 PM   #14
Aptos , California
The wiring diagram
