Old 03-03-2013, 03:47 PM   #1
1985 31' Excella
Birmingham , Alabama
Wiring new converter from 12-volt panel
Following up on another question I had about a new converter. I did purchase a new IOTA DLS-55 amp IQ4 converter to replace the old Univolt Triad Utrad 750-6 50 amp for our '85 EXCELLA.
I left the wires attached to the 12-volt panel and cut them off at the Univolt. There is a LARGE RED wire that connects to the side the red battery cable is connected to so I assume that is positive. A LARGE WHITE wire that is connected to the same side the Black battery wire is connected. Negative I assume. There is a GROUND wire connected to the frame. No Problem. Now there is a that SMALL BLACK wire that I don't have a place to hook it to on the New Converter. New Converter has a Positive, Negative and a Ground terminal to connect the RED, WHITE, and GROUND to. What do I do with the little Black wire? Tie it off with a wire nut and leave it connected to the 12-volt panel? Take it off the panel and safe it for another day? Dispose of it? Does it possibly operate the AC/DC light on the LED board above the front window? Hopefully someone has come across the before. Thank for everyone's help with our repairs.....MAILMAN
Tartimisi is offline   Reply With Quote
Old 03-03-2013, 04:57 PM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I just disconnected it from the panel. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
12 volt
