Old 11-11-2008, 05:37 PM   #1
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Wiring Intelipower 9200
Hi all
Need the electricains to chime in here. I researched and read but I don't know how to wire to my new fuse panel, I am attaching fuse panel I bought from Best Converter (they were closed today) and also a diagram of my Univolt fuse panel. If someone could help as I have searched extensively. I understand where the circuits 1,2,3,4 will go but the car and trailer battery, amp meter and amp meter (red only), and trailer battery ground have me a bit flustered.
thanks in advance
James (trying to prepare for Thanksgiving Trip to Garner) Flint
Name:	Fuse Panel Web.jpg
ID:	71283   Click image for larger version
Name:	Univolt Fuse Panel.jpg
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 11-12-2008, 01:27 PM   #2
1970 27' Overlander
Houston , Texas
Apparently I can't use just the new fuse box so my plan is to pull the fuse box out of the univolt and wire the Intelipower to it. I pulled it and my plan is to simply mount it and run wire from 12v positive from intelipower to post on fuse panel and ground to ground on fuse panel. Then put wires back as they were. If anyone has any advice feel free to let me know.
thanks
Jamse
____________
1970 Overlander
Old 11-12-2008, 01:52 PM   #3
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
thanks
Jamse
Hi The Fintstones; Be sure to fuse both legs with 50 amp fuse or a circuit breaker. This prevents fires when polarity is accidently reversed. Same goes for shorts to ground. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 11-12-2008, 02:04 PM   #4
bertro's Avatar
1971 23' Safari
Groveport , Ohio
These may help, I dont think the amp meter or the shore power light will work with a new set up. I could be wrong. Robert
ID:	71312   Click image for larger version
bertro is offline   Reply With Quote
Old 11-12-2008, 02:15 PM   #5
1970 27' Overlander
Houston , Texas
Thanks for the reply, how do I fuse both legs? Can you explain in simple simon language how to do this. I may have to take to the shop as obviously I'm no electrician. It seemed so easy to do until now.
James
____________
1970 Overlander
Old 11-12-2008, 03:05 PM   #6
1970 27' Overlander
Houston , Texas
Boatdoc
I was thinking, I am installing a GFI 110 plug from shore power to plug the intelipower into, isn't that the same thing?
thanks
Jamse
____________
1970 Overlander
Old 11-12-2008, 03:44 PM   #7
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Hello, flintstone, Boatdoc is talking about an inline fuse on the + and - line between the battery terminals and the fuse panel. The pics I posted shows this with the #4 cables. The #8 is fused just for my amp for the sound system.Robert
Old 11-13-2008, 03:13 AM   #8
boatdoc's Avatar
1973 Argosy 26
James
Hi James;
Because most fixtures in your AS are grounded through chassis, you need to ensure that the negative side is fused in case someone mistakenly reverses battery polarity [by placing negative cable on positive terminal of the battery, and positive cable on the negative terminal].
In case, the polarity reversal [positive side of the battery will be connected directly to chassis ground which is not fused]. Your chassis then becomes the fuse by melting all wires and eventually starting a fire.
Cut both battery cables and install a 50 Amp bus type fuse or manual reset [not auto reset] circuit breakers in each battery cable. If you have two batteries you will need four fuses. Thanks, "Boatdoc"
Old 11-15-2008, 03:57 PM   #9
1970 27' Overlander
Houston , Texas
Done, I think
Well I'm finished with mine, yea!, Here are a few pics. I pulled the fuse panel from the old Univolt as the one I bought from best converter is for 20amp only and I needed two 40 amp circuits for car and trailer battery. Before I installed I hooked up everything to see if all worked and it did. Then I put a wood box together and mounted old fuse panel in it, it will also have a cover to keep moisture out. Ran positive and negative to fuse panel and ran a new positive and negative line to battery in rear compartment. Everything seems to work as it should, let me know if anyone forsees any problems. i had a heck of a time finding the 50amp inline fuses, the place I found them was a car audio store. I installed them but the intellipower has reverse polarity protection but better safe than sorry.
James
Name:	Old Univolt.jpg
ID:	71398   Click image for larger version
Name:	Fuse Circuit Test.jpg
Name:	New Fuse Box.jpg
ID:	71400   Click image for larger version
Name:	New Intellipower.jpg
____________
1970 Overlander
Old 11-17-2008, 12:44 PM   #10
1976 24' Argosy 24
Milford , New Jersey
James, glad to see you worked out your wiring. I was out in the trailer this Sunday wiring the exact setup you purchased in our Argosy. I too ran into a dead end because the fuse panel will accept only 20amp fuses. Today I went to the Auto store and purchased a 50 amp circuit breaker for the battery and a 30 amp for the tow vehicle wire. Should have it together tomorrow night. George.
Gkiesel is offline   Reply With Quote
Old 11-17-2008, 05:59 PM   #11
1970 27' Overlander
Houston , Texas
Gkiesel, good luck.
I was really stressing out because I took it all apart with a trip planned at Thanksgiving. I made it much more difficult that it was. Randy at best converter was very helpful as well as the members here as usual. Looking at the Univolt after I removed it I'm suprised it worked as well as it did other than the boiling issue, it never hummed or kept us awake like we have heard here on forums.
James
____________
1970 Overlander
Old 01-19-2009, 08:07 AM   #12
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The cart or the horse?
I'm doing the same installation as the above. I have a few questions I would greatly appreciate some advice:
1. Should I wire the Intellipower to the battery and then back to the old univolt fuse panel, or, from the Intellipower to the back of the univolt fuse panel and then to the battery (as the univolt was originally wired)? Does it matter?
2. To keep the power on light I assume I wire the black wire to the + connection on the Intellipower, right?
3. The ground conection on the bottom of the Intellipower is wired to the skin or frame, right?
4. What do I need to do to keep the ammeter function?
5. What do I need to do to keep the battery charge level function?
6. My Intellipower is 45 amps. Do I need to change the Univolot fuse panel fuses from 40 amps to 45 or 50?
7. The Intellipower will fit piggyback on the back of the old Univolt case once the Univolt guts have been removed. Any reason not to do this?
Marshall
Lumatic is online now   Reply With Quote
Old 01-20-2009, 07:53 AM   #13
1970 27' Overlander
Houston , Texas
Marshall
Hi Marshall
Hope this helps but I'm no electrician. . .
1. I wired one hot to battery and the other hot from intelli to fuse panel.
2. I used original fuse panel so not sure, I read somewhere that when you wire the 110v plug, wire the "on" light to a 12v (similar to a calculator charger) and plug into 110, or you could plug a nightlight or similar into 110v.
3. Frame
4. ? used my original fuse panel so not sure
5. same answer as 4
6. No
7. why do this? i'm not sure unless space is limited or makes mounting easier or using original fuse panel?
Good luck
James
____________
1970 Overlander
Old 01-20-2009, 06:03 PM   #14
Lumatic's Avatar
1993 34' Excella
Images: 16
Unitellipower
Here it is ready to wire in. Salvaging the Univolt case supports and protects the fuse panel and wiring, still allowing access to the Intellipower.
intellipower 9200 jpancini Batteries, Univolts, Converters & Inverters 6 09-06-2008 01:28 PM
Installing an Intellipower 9200 29348 Batteries, Univolts, Converters & Inverters 16 06-17-2007 09:48 PM
InteliPower wiring Finn Electrical - Systems, Generators, Batteries & Solar 9 01-27-2007 05:02 PM
Intelipower wiring help Safari64 Electrical - Systems, Generators, Batteries & Solar 5 09-06-2006 02:11 PM
Intellipower 9100 vs 9200 Safari64 Electrical - Systems, Generators, Batteries & Solar 15 09-05-2006 02:56 PM
