01-07-2013, 05:22 PM
1966 24' Tradewind
Fall River
, Massachusetts
Wire gauge from Battery to Converter
Hello all,
I am still chipping away at restoring my trailer and I am currently wiring the converter. All is going pretty well but I have a simple question. What gauge wire should I use to go from the batteries to the terminals of the converter? I am planning on putting the batteries within 6 feet of the converter which is a Progressive Dynamics 4045.
I ask because I purchased some nice 4 AWG wire and it seems a little big. I barely fits into the battery terminals of the converter and even at that, some of the wire fibers are not in contact. I have heard that 4 AWG is a good choice and to always lean on the size of a larger gauge but am I missing something here? Thank you all.
01-07-2013, 05:45 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
You are not pushing a high amp motor. A 10 gauge wire will do fine for a simple Airstream install.
01-07-2013, 05:55 PM
1966 24' Tradewind
Fall River
, Massachusetts
Wire
Thank you. Could it be salvaged to wire a couple of solar panels the battery?
01-07-2013, 05:57 PM
Merkel
converter wire size
While I do not know the size of wire required for your application, I do know that in general use 10AWG is rated at 30 amps. That seems a little light, in my estimation. Many times a finer stranded wire is used, such as welding cable as it is easier to work with in bending as well as increasing ampacity.
01-07-2013, 06:32 PM
1991 34' Limited
Wichita
, Kansas
Here is an ampacity chart Ampacity Charts. These charts are typically set up for a maximum run of 50 feet and the recommended wire gage would drop the voltage no more that 2%. Note: this chart is addressing alternating current, but it will work equally well with direct current (any voltage).
Since the Progressive Dynamics 4045 is rated at 45A maximum DC output, the maximum charge rate to the battery would be 45A (here's the installation manual link, but you probably already have a printed copy http://www.progressivedyn.com/pdfs/1...ish%20Only.pdf). So the bottom line is that you would be absolutely fine with 8 gage wire.
Steve
01-07-2013, 06:33 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
I just rewired an Argosy 20' and I used #8 for a 4 foot run. I personally would use either a #8 or #6. jmho. Everybody will have their own thoughts on this I am sure.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
01-07-2013, 07:46 PM
1993 34' Excella
Estancia
, New Mexico
#10 would make me a little nervous. Bigger is better.
01-07-2013, 08:01 PM
Central
, Mississippi
I decided to locate my batteries across the isle from the charger location/fuse block so I ran a pair of #2's under the floor. This gives be the option of locating an inverter near the charger and not have to worry about the voltage drop.
All in all, it was just as easy to go BIG as it would have been to go too small.
01-07-2013, 08:20 PM
Guest
wire size
I just rewired my 65 Caravel. I placed two six volt Trojan bats behiind the propane bottles in a diamond plate shoe box. I ran #4 welding cable to a splice where the original 12 volt battery was under the bed. I used #6 awg from the coverter to the splice. I think #10 was a little light for a 5 foot run.
SK
01-07-2013, 08:39 PM
Western
, Massachusetts
West Marine used to have a better page on this, but their current Wire Size Guide is good for visually showing the effect of length on wire and choices. I liked their last detailed chart of 2% voltage drop better. It pushed the recommendation up 1 size in many cases.
According to the chart, 10 gauge for 6 feet would work. That said, I usually go larger -- not quite as much as Vernon, but close.
I just installed a PD 4045 and used #4 wire for a 3 foot run. If I didn't have it handy, I would have bought #6. BTW, the #4 sounds like severe overkill for solar, but it would work.
