Old 04-21-2018, 03:02 PM   #1
Utah Man's Avatar
2007 27' Classic FB
Richfield/SLC , Utah
Winter Battery Maintenance: Do Anything Differently Next Year?
To any battery experts (incl. those with lots of years of winter RV battery maintenance): see photo for configuration used the last couple of winters. What might you suggest doing differently next year, if anything, with the battery maintenance set-up or practice?
I pull both the 2 RV and 1 TV battery in late fall and stored them in the house garage. The 2 RV batteries are kept wired together in parallel all winter. Once a month I hooked up the Duralast 2 amp battery maintainer and topped them off (unit shows green light when done.)
All winter long the Optima TV battery would illuminate the ďBad BatteryĒ light once complete (itís 3 years old) but I kept charging it monthly anyway. Last night, I took it down to the local tire/battery shop, they tested it and indicated it tested fine. They kept it overnight to fully charge it.
Presumably, when I reinstall all the batteries next week (unit is kept elsewhere in Southern Utah), all will go well without problems.
Itís a bit of a head scratcher to me, and I wonder what Iím missing on possible root cause / deficiency.
What would you do differently with the battery maintenance set-up or practice of monthly charging? Itís cold in the garage but mostly stays above freezing due to heat transfer from the house.
Thanks in advance for your insights and comments.
Regards - Ron
(p.s. Iím not asking for advice to dump the Interstates and upgrade batteries etc. as Iíve read many of those threads - just not looking to sink a lot of $$ at this time into a unit I may replace soon.)
Utah Man is offline   Reply With Quote
Old 04-27-2018, 04:45 PM   #2
Utah Man's Avatar
2007 27' Classic FB
Okay... now comes the ďacid testĒ... letís hook it up and see if all is good.
Old 04-27-2018, 08:55 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Perhaps you have a faulty maintainer.
I leave the batteries in my trailer and just plug it in to the garage every month or so to top them off. They are only 3 years old, but still good, though.
CRH is offline   Reply With Quote
Old 04-28-2018, 03:31 PM   #4
Utah Man's Avatar
2007 27' Classic FB
All went well... no problems with batteries. Successfully hauled up to Salt Lake City for other TLC (trailer and TV.). There are pros/cons of not keeping the trailer up here with us in the City.
Regards - Ron
Old 05-01-2018, 06:38 AM   #5
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
one thing you can do, if you have flooded type batteries, is to check the specific gravity of each cell when you first take them out, and every month or so to see how they are doing.. you can not really depend on the charger for accurate info. voltage and SQ are the heart and blood of flooded batteries.
You ever read stuff on batteries at handy bob solar?? highly recommend
https://handybobsolar.wordpress.com/...andybob-solar/
Regards - Ron
Attachment 309196
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 05-03-2018, 06:45 AM   #6
Utah Man's Avatar
2007 27' Classic FB
Thanks, Carl - appreciate the info. and referral. Looks like a great blog (havenít seen before.)
Regards - Ron
Old 05-03-2018, 08:22 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I use flooded cell batteries in the trailer. When the trailer is stored or just sitting I put the trailer on a timer and power it 1 hour per day. Keeps them charged enough not to freeze and break.
Old 05-13-2018, 06:21 PM   #8
carl2591's Avatar
2005 31' Classic
during summer when we are using the unit I just make sure to unhook the LP detector to keep batteries up.. During winter I take them out and put in garage with a harbor fright trickle charger. Put it one for a week or so and then off for a month.
Carl, Raleigh NC
Old 05-13-2018, 06:44 PM   #9
2019 30' International
Pennsylvania , Pennsylvania
I pull the batteries in winter and put them in the garage on a Battery Tender. Once spring arrives I make sure the cells are full and then put them on a NAPA charger I have. Then if the SG is good in all the cells I put 'em in the airstream.
Between summer trips I don't plug in unless I'm going to run the fridge, I just put that Battery Tender on them until the next trip.
majorairhead is offline   Reply With Quote
What would you do differently? Lingtodt General Repair Forum 9 03-13-2017 10:27 AM
What Should We Do Differently Next Time demijac Full-Timing, Winter Living & Workamping 15 02-24-2015 09:02 AM
New Fantastic Fan Operating Differently SilverCabin Roof Vents, Skylights & Fans 17 09-05-2014 10:16 AM
What would you do differently on ur AS? RavenDog Our Community 18 07-07-2013 11:11 PM
Anything I need to know / Picking Basecamp up next week msneedtx Base Camp 1 04-27-2012 04:10 PM
