Old 10-18-2008, 05:06 PM   #1
1992 36' Land Yacht
hubbardston , Massachusetts
winter batteries
just put 2 new interstate batteries in my 92 36ft landyacht motorhome
storing it in non heated building
why can't i just leave the batteries in it until spring????
i can turn off main battery switch
same batteries in truck!!!
kevin
kepko is offline   Reply With Quote
Old 10-18-2008, 05:54 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I would think you can, I would just take the cables on the batteries as well as an added caution...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-18-2008, 06:07 PM   #3
Batteries
Flooded cell batteries discharge at the rate of about 1% per day when not in use. If you leave them over the winter, they will likely be completely discharged by spring. A better approach is to take them home and put them on a charger intended for maintaining batteries. Flooded cell rv/marine deep cycle batteries should not be discharged below 50
% for best life.
1985 25' Sovereign
Corner Bed
2003 3/4 ton Suburban
6.0, 3.73
Bellingham, WA
alan is offline   Reply With Quote
Old 10-18-2008, 06:25 PM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Interstates will last you about two years, with luck.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-18-2008, 08:16 PM   #5
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Biggest issue is that even with the main 12 volt disconnect off, you will still have some drain / loads from e.g. propane / monoxide detector. They will drain your batteries dead over winter if the self-discharge doesn't. Then they'll freeze in Mass. winter and they're goners.
Best bet: take em' home and leave em' on a Battery Tender or some such over the winter. Top the electrolyte up in the spring and you're good to go.
AirsDream is offline   Reply With Quote
Old 10-19-2008, 06:55 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
What they said
Take 'em out, keep 'em warm, topped up and on a maintanence charger.
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 10-19-2008, 07:34 AM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I bought a "Battery Float Charger" from Harbor Freight for $15. It only comes on only when needed and keeps the battery charge topped off.
I have had an Interstate deep cycle battery for more that 5 years. My Univolt even boiled it dry once or twice. Still works good for me.
Old 10-19-2008, 03:39 PM   #8
New Borockton , Alabama
Images: 21
Without a power source, I would pull them if you don't plan to charge them until spring.
If you have a power source, a maintainer would keep them topped off.
MA can be brutal in winter as I'm sure you know and when they discharge, sulfation and stratification will reduce their ability to hold a charge.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
www.bestconverter.com
Old 10-20-2008, 04:27 PM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I'm facing the same decision. I can leave my batteries outside in the AS with a Battery Minder attached, or take them out and bring them inside, still with a Battery Minder attached. Does it matter which I do?
Old 10-20-2008, 06:20 PM   #10
"Bertha" the 53 Ford, sits in an unheated garage with a 6 volt Battery Minder all winter with no problems. Our old Burb has sat all Summer on the pad also with a Minder on it, five months with no water loss. The only hassle is the extension cord out to the pad.
I take the batts out of the Stream. Ran out of minders and extension cords.
RLC
RLC
"Tahawus"
Old 10-20-2008, 11:45 PM   #11
Mexray's Avatar
1978 28' Ambassador
Morada , California
A battery minder, if properly sized to the batteries, will keep them at a state of full charge, and will help keep them from freezing.
These devices are inexpensive, and well worth the money to lengthen the life of your batteries...plus they will be ready to use when the spring thaw rolls around...
Ray & Pat; Morada, CA
Old 10-27-2008, 06:54 PM   #12
Sierra Papa
2007 25' International CCD
Preston , Idaho
I keep my AS in a insulated, not heated hanger. I have 110 power available. Is it advisable to just plug the AS into shore power and use the system to keep my batteries charged? Or would an investment in a "maintainer" be advised?
Sierrapapa is offline   Reply With Quote
Old 10-27-2008, 07:37 PM   #13
Never trust an un-watched Airstream...A Battery Minder or a good float charger is a worthwhile investment, ask me how I know.
RLC
RLC
"Tahawus"
Old 10-27-2008, 08:16 PM   #14
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Originally Posted by ROBERT CROSS View Post
................ ask me how I know.
How do you know? Did you have problems keeping the AS plugged in?
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
batteries jhenry Member Introductions 5 10-19-2008 02:03 PM
Leaving batteries connected over the winter StAlphonzo Electrical - Systems, Generators, Batteries & Solar 7 10-02-2008 02:44 PM
Batteries SJ Brown Batteries, Univolts, Converters & Inverters 9 06-17-2008 05:59 PM
Tie House & Coach Batteries for Winter Storage? N2XBW Electrical - Systems, Generators, Batteries & Solar 5 11-23-2007 10:29 PM
Batteries???? FOB Batteries, Univolts, Converters & Inverters 6 07-09-2006 10:33 AM
