Old 02-22-2015, 02:09 PM   #1
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Will a 150 watt inverter run 19" TV
I looking into using a 150 watt inverter to run my TV and maybe a DVD player.
The samlex 150 watt pure sine wave inverter. I have a 12volt outlet under TV does anyone know if this will work? The numbers check out TV DVD watts should work but numbers and reality are sometimes worlds apart. Thanks for any input. Rand
grizbear is offline   Reply With Quote
Old 02-22-2015, 02:45 PM   #2
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Yes. LED will use less than 45 watts.
I ran a 19" from a Samlax 120 without issues.
My Sony 23 LCD uses 95w.
Kelvin
Old 02-22-2015, 02:50 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
You can buy a high quality Xantrex 600W inverter for less than $160. These are great converters, BTW, much better quality than the WFCO's that A/S puts on trailers. A call or email to Randy and Best Converters ....he can answer any questions you might have.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-23-2015, 05:38 AM   #4
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Thanks guys I didn't want to have to do any heavy wiring for a larger inverter just to run a small LED TV DVD. Thanks, Rand
Old 02-23-2015, 07:33 AM   #5
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I ran my 120w Samlex off the 12v adapter port in my 17' Casita to watch TV on my 19" HDTV/DVD Magnavox. Used a 60w solar panel to charge the single grp 24 battery during the day.
Kelvin
Old 02-23-2015, 07:52 AM   #6
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
.......so why not get a combo TV/dvd that runs off 12vdc? About the same price as an invertor.
Ahab is offline   Reply With Quote
Old 02-23-2015, 09:15 AM   #7
Johnco's Avatar
2006 19' Safari
Anaheim , California
Check the transformer on the TV you have right now. If it's reducing the power to 12 volts you can buy the correct plug and power it off of your 12 volt outlet direct. My 19" Insignia from Best Buy works great this way.
Johnco is offline   Reply With Quote
Old 02-24-2015, 07:39 AM   #8
grizbear's Avatar
2004 25' Safari
Crestview , Florida
I already have the TV/DVD and I could charge my laptop with an inverter and could use the inverter in truck so the wife can charge her Ipad she reads during travel. Thanks for all the input. Rand
Old 02-25-2015, 08:22 AM   #9
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I charge my laptop, IPhone and iPad in the truck or in the coach. You don't need an inverter.
Old 02-25-2015, 09:17 AM   #10
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I use a 150w invertor to power a 24"LED TV, BluRay and PC speakers w/subwoofer. I use the 12vDC outlet to plug in the inverter, then plug a power strip with the components plugged in into the inverter. When I want to connect to 120AC, I just unplug the power strip from the inverter and plug it into the adjacent 120 outlet. Been doing it this way for years and works great.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 02-26-2015, 06:22 AM   #11
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Thanks Steve that is just what I am planning to do. Wanted to know if it would work in the real world not just on paper had someone at RV repair center that said I would need a 1000 watt hard wired inverter maybe he was hoping to sell an inverter and install. Thanks again. Rand
Old 02-26-2015, 08:59 AM   #12
TinShack's Avatar
2005 28' Safari S/O
I turn the inverter off when not using it as there is some phantom drain to the batteries if left on.
Steve
Old 02-27-2015, 03:01 PM   #13
2015 28' International
Nelsonville , Ohio
150 watt inventor is fine have used similar set up in 30ft Classic with dvd...No problems
rebel1957 is offline   Reply With Quote
Old 03-19-2015, 05:57 PM   #14
2018 19' Flying Cloud
Eugene , Oregon
I was thinking of getting the samlex 150 watt pure sine wave inverter for my new Bambi Sport 16. However, I can't find any 12v receptacle. Is the not one on the Sport 16? Will I have to install one?
tjwoods1 is offline   Reply With Quote
Old 03-19-2015, 06:15 PM   #15
Naples , Florida
Sorry to have to disagree, but NOTHING that comes from Xantrex any longer is of high quality. They were at one time, over 10 years ago.....but not now. EVERYTHING they sell is made in China.......and NOTHING they sell is field repairable.
Look to Morningstar for smaller, high quality inverters and Magnum for 600 watt inverter-only units and 1000 watt or higher inverter chargers. All made in the USA and fully repairable in the off-chance that they need it.
lewster
600 Watt Inverter PWirtz Batteries, Univolts, Converters & Inverters 13 01-10-2015 12:01 PM
Generac iX 2000 Watt Portable Inverter Generator Frank&Mike Generators & Solar Power 21 11-06-2014 06:20 PM
Question on Yamaha EF2400iSHC - 2000 Watt Inverter Generator. Ditter Generators & Solar Power 22 02-19-2013 06:31 PM
2000 watt Cen-tech Inverter On Sale TinCanW/6 Full-Timing, Winter Living & Workamping 7 01-08-2013 07:53 PM
Need options for 3000 watt inverter Dwight Batteries, Univolts, Converters & Inverters 1 08-30-2011 08:55 AM
