03-07-2016, 01:01 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Why waiting 3-5yrs for Lithium prices is wrong
Opinion piece.
Not much is going to change with lithium between now and 5yrs in terms of support or pricing. I keep seeing this come up where people say they're going to wait to 3-5yrs to see what changes, because lithiums are so expensive. Lithium is already 10+yr old tech with various chemistries on the market. There is a lot of support, and it's priced appropriately already.
I am going to attempt to explain and educate here that the prices are cheap currently, and today is better to jump to lithiums than waiting, when prices are more likely to increase based on inflation and a devaluing dollar.
What many don't factor into the price of lithium is the cost of the additional components required to have a good system. I did a detailed write up about these here: https://boldandadventurous.com/our-d...-upgrade-pt-1/
To make it work, you'll need a BMS (battery management system) and cell balancers, wiring upgrades, breakers and the like. If you remove those from the cost, you'll see lithiums are only a few hundred more than a say an AGM Lifeline.
To give you an example a 100aH 12v lithium by itself is $620.00 vs a $270.00 for a 12v Lifeline of 100aH - that's a $350.00 difference and appropriately priced for benefits and materials. That difference here, the lithium has 80aH usable where the Lifeline has 50aH
To get close to that you'd need to buy two 6V batteries at $287.50 each to reach 110 usable amp hours.
That's $575.00 - and you can see where this is going.
So by all accounts, lithiums are priced right for the market. Waiting is pointless.
If you look at AMSolar's kit which is a good kit and then just compare it to a Trojan battery you are not accounting for all the additional components that are in the lithium battery kit. It's not a fair or accurate assessment.
It should be noted, that these components have been shrunk and stuffed into some lithium replacement batteries that are already in 12V form factor. Take the Smart Batteries for example. They feature integrated BMS and balancer. These are more complicated then a simple lead acid type battery.
An easy way to think about it, is wet cell batteries are dumb phones where lithiums are smart phones. Don't compare that 7/11 prepaid dumb phone to an iphone. Cheers.
Notes: Prices used in example from 3/7/2016 sources:
http://www.bestconverter.com/Lifelin...ries_c_58.html
http://elitepowersolutions.com/produ...x.php?cPath=25
http://www.lithiumion-batteries.com/
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
03-07-2016, 01:33 PM
2011 23' International
clovis
Hi Mike
I'm a bit confused. Your statement...
"What many don't factor into the price of lithium is the cost of the additional components required to have a good system."
Are you suggesting that if you use a lithium battery you need to buy additional components to have a good system? Or that a traditional system would require additional components to produce a "good system"?
JG
03-07-2016, 02:09 PM
2008 25' Classic
Full Time
Battery management systems are external or internal and you have to use a different charger designed for lithiums or that can be programmed to charge lithiums. They need to be stored inside out of the weather and be kept within specific temperature ranges for charging. The second photo showing the battery form factor will probably be the future norm if the cost can be brought down where more RVs will accept them. The RV market is not very big for lithiums because I'm thinking most RV owners don't need them. One or two wet cells and hook ups are all they need and where I live you need hookups to run the darn AC most of the year so why invest in an expensive battery system. For Bold, who lives off the grid, they are ideal and worth the expense and he is an educated tinkerer.
I think there has to be an untapped, large, potential market for any newer technology to come down in price. I don't think the RV market is big enough. If that were true then absorption style refrigerators would be under $500 and roof top Acs should be almost as cheap as those window ACs in houses.
Kelvin
03-07-2016, 02:35 PM
Nomadic
, USA
Same reason they don't ship Airstreams with Michelin tires. Lead acid will always be cheaper and the manufacturers will always ship with those.
What I'm trying to get across is price wise you can't look at this
or this:
and wonder why it's three times the cost of this
One is dumb, has no required electronics, the other two are smart and have more components than just the cells. Once you understand that, you can make a more informed decision in comparing the cost benefits.
The same way you can compare pros and cons of lead vs agm.
And I think that the prices in the market are not going to come down. As they're already down. AGM's cost less a few years ago, than they do today. Do a search around here. You'll see it.
03-07-2016, 02:46 PM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
You can support your argument more when you look at the cost per Ah over life expectancy. I haven't run the numbers, but because you can drain lithium batteries down so far and they last so long vs. other types it makes the long term cost per Ah reasonable.
Of course at the expense of up front costs and temperature range issue.
@living.somewhere.yonder | Instagram
03-07-2016, 05:12 PM
2013 27' FB International
El Dorado Hills
Good write up and segregation of costs Bold. Yet as another poster noted it comes down to what's needed. If I think honestly of my own needs, wet cells are adequate. No microwave or AC but they're good enough for the rest of the demands. If instead I think of what I want... well then a big bank of lithium batteries to power everything. Unfortunately my wallet balks when spending on wants.
03-07-2016, 08:21 PM
1986 25' Sovereign
2008 F350, 6.4L diesel
, Oak Harbor, WA
How about this:
Lithium:
Pluses: lighter, a lot more power for the same volume (takes less space), sealed, last longer, partial charge OK, makes users purchase a smart charger or gets rid of the crappy factory chargers (and the collateral damage they cause to lead acid batteries).
Minuses: cost more, require changes to trailer wiring, increase user's expectation for the 12VDC electrical system such as power monitor, needs a better controlled environment for charging, cell lugs often exposed but not is all cases.
03-08-2016, 11:43 AM
2017 30' International
Broomfield
SmartBattery looks like the way to go. Seems plug and play - drop 'em, change out your converter / charger and you are good to go. Sweet.
Does anyone have any specific experience with them they can share? I just bought 2 new group 27 Lifelines to keep the renovation budget under control but I think I'll make the switch to lithium ion in 2-3 years when these kick the bucket.
03-08-2016, 06:20 PM
2015 25' FB Flying Cloud
Eugene
, Oregon
Thanks, BoldAdventure (aka Mike) for another great, informative post. I really appreciate you posting and documenting mods so well for all of us!
03-08-2016, 06:32 PM
2013 31' Classic
billings
, Montana
I thinks I will keep my interstates and spend my monies on the flathead 59ab to put in my model A ford...
03-08-2016, 07:22 PM
2013 25' Flying Cloud
Wheaton
Cold weather Lithium
I understand Lithiums should not be charged in cold weather, below freezing.
For snowbirds living in cold climates, this can be a tricky situation.
The batteries can be removed and brought inside while in storage prior to travel but what is one to do when transporting the trailer when the weather is below freezing? I'm thinking of the charging circuit which is part of the 7 way trailer connector. And the impracticability to keep the batteries warm inside the trailer during travel.
Greg
03-08-2016, 07:29 PM
Naples
Greg
Simply remove ALL sources of charging if you have lithiums and plan to travel in sub-freezing ambient temperatures. There is no issue with USING them to -20şC….just don't CHARGE them below 0şC (32şF).
Besides, your alternator is not a preferred charging source for lithiums.
Providing location-specific heat to keep lithiums above 0şC is not that difficult.
Of course, YMMV!
lewster
03-08-2016, 07:30 PM
Nomadic
, USA
Put it on a disconnect. Easy peasy. I let it get to 40 degrees in my Airstream last night and the batteries still were reading 72 degrees. If they're inside they'll stay warm for longer than you think.
Just over thinking it.
03-08-2016, 08:14 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
One cool thing about old lead acid batteries is if I ruin them one way or the other I can replace them from any number of off the shelf local sources and not kick myself for wasting a load of money.
A lot of folks like me, or others who let their trailer sit for months at a time unaccompanied in storage lots, etc, might consider lead acid more economical both short term and long term.
I can see where these would be a good investment for your use Bold, but I don't think so much for mine.
Talis gentium ceciderunt.
03-08-2016, 09:36 PM
Nomadic
, USA
That's not really the point of this post. I don't know why you all need to justify your use of lead acid batteries to me.
03-09-2016, 12:50 AM
1978 28' Ambassador
Morada
Eco-ion
Check out Pleasureway.com that use (2) 100AH lithium batteries as std equipment on all their Sprinter chassis RVs. They use the Eco-ion product.
Looking at their videos, it looks like they use 'plug & play' type batteries in a sealed cabinet.
They claim 2000-3000 life cycles, which is many years of service for most RV users..!
With more usable amp hours, less weight, quicker recharge times & longer life cycles - these batteries will become essential for serious RV owners...IMHO...
03-09-2016, 05:42 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Smart choice....
03-09-2016, 05:53 AM
Vintage Kin
Fort Worth
Good job, good thread.
03-09-2016, 05:55 AM
2014 25' Flying Cloud
Cuddebackville
, New York
Im not pro or con any battery, but this seems like a stretch to justify cost.
Basically you're saying the batteries aren't all that expensive, but you need to buy a lot of other stuff if you want them to work.
I'm not trying to start an argument here, I just think the need for lithiums can be justified in better ways.
2019 Ford Expedition Platinum
03-09-2016, 06:35 AM
1972 31' Sovereign
Benton
, Arkansas
"Justify"?
No.
I am just pointing out that I am neither waiting for prices to drop or not waiting for prices to drop, while also pointing out that dropping a thousand bucks (or more) on a battery system that carries with it the promise of even greater complexity while playing the role of beta tester might not be in everyones best interest.
Sorry, but the title and content of your thread invited my response. I am not waiting for prices to come down, but if they did come down A LOT, I might give the technology a try after gauging its reliability, ease of use, and practicality.
These batteries not charging well from my tow vehicles alternator is kinda a downer for my use too.
