Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 11-15-2004, 06:05 PM   #1
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Why the battery residue?
Got my batteries home now, in the garage, charging...set the thing on maintenance....guess everything is OK....did what was advised about the parallel stuff...have used my jumper cables to connect everything . Will get shorter cables tomorrow.
I don't understand why the driver's side battery is so "dirty". The mucker seems to exude nasty white stuff (and it stings) acid I think. What is going on there? What should I do diff? I understand cleaning up with baking soda, but where is this stuff coming from. It has spoiled the looks of my door (driver's side only) of the battery compartment and the fake chrome below it.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 11-15-2004, 06:20 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
The white stuff is lead sulfate. It comes out the battery vents as sulfuric acid aerosol and reacts with the battery terminals (lead) to form lead sulfate.
Non-contributing deadbeat.
Old 11-15-2004, 06:21 PM   #3
silverback
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
Kistler,
If I recall correctly the white stuff is oxidation. Usually caused by a poor (loose) connection. A solution of baking soda will clean it right up. Just what old tooth brushes are good for.
Ken
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is offline   Reply With Quote
Old 11-15-2004, 06:39 PM   #4
Kistler
Kistler's Avatar
Thank you, guys....just wonder why I got "lucky" and have this....didn't touch the batteries at all.
Today, I removed them to bring them home to the garage and put them on a charger...won't be leaving now until March. Did notice especially the driver's side battery had the oxide residue....learned that from you
The connections were tight. It really doesn't matter but I am trying to preserve the Airstream for a while.
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 01:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 09:43 AM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 06:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 08:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
