Old 12-22-2010, 12:55 PM   #1
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
why can't I use an inverter ?
all I want to do really is charge up the one 12 volt battery in my trailer,and as luck would have it my power cord in the rear storage area is 90 foot long so it would easily reach the inverter with no other cords,what do you think?? bad idea ?
Rollerboy is offline   Reply With Quote
Old 12-22-2010, 12:57 PM   #2
Ottawa , ON
What inverter?
Old 12-22-2010, 01:05 PM   #3
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Sorry ,one installed in the tow vehicle Chevy van
Old 12-22-2010, 01:08 PM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Inverter converts DC to AC. You want a battery charger-turns AC to DC.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-22-2010, 01:10 PM   #5
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
what I am asking about is this, how can I use my nice long trailer power cord,and my vans motor to charge up trailer battery ? seems to me ,if it is plugged in the trailer converter will do with the electricity as it needs, Yes ?
Old 12-22-2010, 01:30 PM   #6
1986 25' Sovereign
Plant City , Florida
Correct! This would work but would not be very efficent. You would be better to let the Van run and charge the trailer through the 7 pin cord that you hook up for travel.
ck21084 is offline   Reply With Quote
Old 12-22-2010, 02:09 PM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
If you have cables that would reach, just using jumper cables would be faster and cheaper. Through the 7 pin would not be efficient at all. Either way you are going to burn a lot of gas to do this.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 12-22-2010, 02:41 PM   #8
1986 25' Sovereign
Boondocker,
How many amp would you expect with cables vs. the 7 pin? I have registered 40 amps with mine however I have never measured a set of cables. I would think that the end clamps would be very lossful.
I do agree that this is a very expensive generator.
Chris
Old 12-22-2010, 02:59 PM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Originally Posted by ck21084 View Post
Boondocker,
Chris
Im not an electrician. Having said that, I dont see how you could possibly get 40 amp through the 7 pin. I would guess the number to be in the 2 amp range...... Not to be a smarta**, but are you sure the decimal point is in the right place? In any case, I would expect the large diameter of the cables and properly connected clamps to transfer a far larger current than the umbilical. Thats just me though, maybe the electrical gurus will weigh in.
Rodney
and the
My Blog
Old 12-22-2010, 03:09 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you are going to run the Van to charge the battery. Why not just plug it in to the Umbilical Cord (for your trailer lights)?
Old 12-22-2010, 03:10 PM   #11
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Chris, to get 40 amps down 15' of wire requires 6 gauge wire. Do you have a custom wired 7-way?
I vote for hooking up a cheap 55 amp harbor freight battery charger if you have 110v power available. They're about $39.
newroswell is offline   Reply With Quote
Old 12-22-2010, 03:11 PM   #12
1986 25' Sovereign
I am sure that this is correct. I used a 1000amp probe that is certified that I use for work. I have to send it back to fluke every 3 years.
I have 8 awg wire for charge lines so this may affect my results.
No big deal on the smarta$$ I am one at work all day and sometimes at night too. Lol
Old 12-22-2010, 03:14 PM   #13
VIKING's Avatar
Boulder Creek , California
You would lose a lot of juice converting the dc to ac and back again just to charge the battery, not to mention the 90' of cord it has to carry over.
Alternator to inverter to AS power supply to battery=
It may work but it would probably take a long time to charge, and lots of fuel.
Rich the Viking
VIKING is offline   Reply With Quote
Old 12-22-2010, 03:19 PM   #14
Chief Chili Cook
newroswell's Avatar
Lots of fuel considering most alternators won't put out too many spare amps at idle, so ya got to get the RPM's up, by driving. OR you have the ambulance prep package on a Ford with a high idle switch! Either way, cheap HF battery charger is hard to beat.
inverter J Goertzen 2002 - 2005 International 4 04-11-2010 10:00 PM
Inverter - On or Off? big_john Batteries, Univolts, Converters & Inverters 23 11-23-2009 01:56 PM
Do I have an inverter? cmreumund Batteries, Univolts, Converters & Inverters 4 02-01-2009 07:10 AM
anyone have an inverter? safari25-05 Electrical - Systems, Generators, Batteries & Solar 10 01-19-2007 11:23 PM
Inverter???? Kestrell General Motorhome Topics 12 06-18-2006 09:25 PM
