Old 12-22-2010, 03:24 PM   #15
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
In an emergency once I tried to put some juice in my battery, hooked it up to the truck, ran it forever, revved it and it did next to piddley nothing...
cclarkego is offline   Reply With Quote
Old 12-22-2010, 04:13 PM   #16
Mexray's Avatar
1978 28' Ambassador
Morada , California
The only fairly efficient way to charge your trailer battery using your tow vehicle is to:
1. Hook HD jumper cables (2 AWG min wire size) from your TV's battery terminals directly to the trailer battery's terminals...DON'T use cheapo jumper cables that have small gauge wires! Truckers use jumpers with at least 2 AWG size wire - not cheap, but have much less DC voltage loss...
2. This type of connection will insure the greatest charge rate using the TV's alternator...however, realize you're running your LARGE engine for a moderate charging rate, again not a very efficient way to do this - extra wear and tear on your TV, extra fuel required, etc., etc...
3. connecting the trailer's shore power cord into an inverter on your TV is not an efficient charging method, as you lose on both ends converting from DC/AC (inverter) then to AC/DC (converter), PLUS all the additional connections encounted through these components...
4. using the TV umbilical will work, but again you're going to lose efficiency due to the connectors, fuse panel connections, fuses, and the smaller size of wire used in those circuits...this type of charging is designed to charge your trailer battery as you're on the road over a long period of time, etc...
5. if you intend to do this kind of recharging of the trailer battery very often, you're better off saving up your $'s and purchasing a small generator, IE, Honda inverter type (quiet), or similar 'genny'...
Hope that helps...
Ray
Ray & Pat; Morada, CA
Old 12-22-2010, 05:00 PM   #17
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
dang it! here I thought I could be sly and use that long cord to my advantage,looks like a honda is in my future...
Rollerboy is offline   Reply With Quote
Old 12-22-2010, 08:52 PM   #18
Ottawa , ON
That struck me as kinda funny too: how many here have 90' of AC cord connected to their TT??
I hear 90' I think tons of losses through that wire... Whether you are 90' away or not, every time you plug in you add that 90' to the distance the power has to go to your TT.
I'm gonna guess that there's ~30' on my TT.
Old 12-23-2010, 05:36 AM   #19
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
The P.O changed out the power supply cord to 90 foot long,now I think maybe I should shorten it up a bit...
inverter J Goertzen 2002 - 2005 International 4 04-11-2010 10:00 PM
Inverter - On or Off? big_john Batteries, Univolts, Converters & Inverters 23 11-23-2009 01:56 PM
Do I have an inverter? cmreumund Batteries, Univolts, Converters & Inverters 4 02-01-2009 07:10 AM
anyone have an inverter? safari25-05 Electrical - Systems, Generators, Batteries & Solar 10 01-19-2007 11:23 PM
Inverter???? Kestrell General Motorhome Topics 12 06-18-2006 09:25 PM
