Old 06-17-2016, 02:28 PM   #1
MOS
2016 28' Flying Cloud
Queensbury , New York
Which neg.- black wire to disconnect??
Have a 2016 FC 28W. Batteries drain slow when in storage. Put a on /off switch in for the LP gas sensor. I think something else is drawing power when stored.
So I want to disconnect the black , neg - lead to the batteries.
There are two sets of red/black cables going to the batteries from the TT.
Which one do I disconnect or should I disconnect both neg - black leads ?
MOS is offline   Reply With Quote
Old 06-17-2016, 02:30 PM   #2
1991 25' Excella
Stanfield , Oregon
If in dought disconnect both negatives
SpletKay06 is offline   Reply With Quote
Old 06-17-2016, 04:17 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Both they are tied to a common ground point. If you only disconnect one the other battery is still in the circuit.
2004 Excursion 4x4
Old 06-17-2016, 05:17 PM   #4
MOS
10-4 thanks
To disconnect or not to disconnect urnmor Towing, Tow Vehicles & Hitches 36 02-22-2017 10:24 AM
50 AMP fuse on Neg or Positive Pinchy Batteries, Univolts, Converters & Inverters 16 05-29-2011 07:56 AM
Neg. Batt. Fuse location? jamesardis Batteries, Univolts, Converters & Inverters 5 11-02-2008 04:09 AM
Fused Neg. at panel?? Phil Gobie Electrical - Systems, Generators, Batteries & Solar 3 02-19-2007 05:59 AM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
