Which model of wfco do I have?
I’d fix the solar system first. Ours is a kit from AMSolar that I installed myself. Highly recommended.
I’m running 150 watts of solar (one big panel on the roof) with an MPPT controller in the high desert of California. Usually unplugged in storage.
I run one FantasticFan on low to ventilate the Airstream all day. Batteries stay charged and use little water all year round.
Plan to upgrade the OEM stock converter eventually, because on our last trip with shore power available most nights, battery water consumption went up significantly on the old battery boiler fixed output converter. Solar controller also checks temperature at the batteries, and is what I depend on for proper charging nowadays.
Just check battery water levels at least once a month if you have flooded lead acid (conventional) batteries installed.
