Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 11-27-2004, 05:36 PM   #1
boltos
boltos's Avatar
Profile:
Which Deep Cycle Battery?
I have checked my reprinted Service Manual and the original Owner's Manual for a spec on the battery...to no avail. I have a '72 23ft Safari, and just bought a '71 21ft Globetrotter...it came with no battery.
I went to Sam 's Club to buy one and thought I better find out more. I could duplicate the one that's in the Safari..but I really don't know if it's the specified...so, what kinda spec can anyone volunteer that could help clarify what deep cycle batter I need?
Thanks in advance,
Brian Sawyer,
Lexington, KY
boltos is offline   Reply With Quote
Old 11-27-2004, 05:43 PM   #2
Soarhead
Profile:  2005 28' Safari S/O
North Branford , Connecticut
Buy the biggest, heaviest one that'll fit into the space available.
Soarhead is offline   Reply With Quote
Old 11-27-2004, 05:47 PM   #3
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
I forget where I read that Interstate SRM-27's, which I have, are not truly deep cycle.. ??? came with the thing in 2002.
What should I buy? I am with sorehead however, don't have unlimited money, but my wife get's Social Security
Kistler
Kistler is offline   Reply With Quote
Old 11-27-2004, 07:01 PM   #4
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Batteries not included??
Trojan makes some really good deep cycle batteries. It is the brand most often used in golf carts, floor sweepers, etc.Trojan
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 11-27-2004, 07:51 PM   #5
Creampuff
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
Costco sells 2 sizes of marine deep cycle. I'm currently running the largest of the 2 which fits fine in my '67 Safari. I have used the smaller one with good success as well but decided to go bigger for the 3 day boondocking specials.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 11-27-2004, 08:42 PM   #6
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
The Interstate SRM-27s that came in our '01 are pretty sulfated up by now. I never did like it that they were only 85AH, compared to what some of the Trojans provide.
But I've discovered I like battery maintenance even less, so these are going to be replaced with the largest (Group 31 if possible, Group 27 if not), Lifeline AGM deep-cycle batteries I can fit in the compartments. I'll sacrifice some amp-hours for the low maintenance and low self discharge.
Here's the Lifeline Distributor Finder
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 11-28-2004, 11:04 AM   #7
silverback
silverback's Avatar
Profile:  2006 28' Safari SE
Phoenix , Arizona
tongue weight gain with group 27 or 31?
Maurice, These look great, but my rough weight calculation comes in at around 138 lbs for a pair of the group 31s. I haven't weighed my current battery set, but I'm betting they are less. So upgrading the batteries would also affect tongue weight. Or am I being a nit picker?
Ken
4CU Charter Member
2004 Silverado 2500 HD D/A
Honda EU2000i
Hensley Arrow
KE7DUI
silverback is offline   Reply With Quote
Old 11-28-2004, 01:45 PM   #8
71_safari
71_safari's Avatar
Profile:
Images: 12
Ken
Yes, it affects the tongue weight, but it may go up or down, depending on where your battery is located. On many early 70's, such as my 71 Safari, the battery is actually in the rear curbside. I would love a couple of AGM's when my group 27 lead-acid goes, although I may settle for one so as not to add weight overall.
1971 Safari 23
71_safari is offline   Reply With Quote
Old 11-28-2004, 01:57 PM   #9
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I can't get to my trailer right now to read the battery label, but our 71 tradewind came 3 yrs ago with an Interstate RV battery. The battery lives under the rear goucho, and is completely sealed and maintenance free. It has served us very well, despite the low amp hours. It's never gone dead, and it never left us without lights, even before we got the generator. Plus, we use it with the original Univolt, which receives mixed reviews here on the forums.
I can recommend the Interstate product whole-heartedly.
Uwe
Old 11-28-2004, 02:00 PM   #10
Kistler
Kistler's Avatar
Thank you, Maurice, for the info on Lifeline batteries; I guess I'll have to see what the GPL - 27T ones cost. Apparently they are available at the local Batterys Plus here in Tucson.
They apparently will raise my tongue weight about 25 lbs. I think my Interstate SRM-27s weigh about 50 lbs each.
I think I'll wait until March to buy batteries, however. We are not going anywhere except for a little jaunt in February to Las Vegas and will have full hook-ups. One of the SRM's has a reading of 520 and one 470 so I guess they's do for reststop pump running.
Kistler
Old 11-28-2004, 02:41 PM   #11
silverback
silverback's Avatar
Phoenix , Arizona
On our CCD the two Interstates are in a compartment just behind the propane tanks on the tongue. Kistler, thanks for doing the weighing (I'm sure yours are pretty close to mine) and the shopping research. It looks like we have Batteries Plus in Phoenix also.
Ken
4CU Charter Member
Honda EU2000i
Hensley Arrow
KE7DUI
Old 11-28-2004, 02:57 PM   #12
Kistler
Kistler's Avatar
de nada....it was Maurice that did it.....thank you again Maurice!
I am a little worried about the size...the SRM-27s are about 6.5 in wide X 8 high X 12 deep.
The Lifeline GPL-27Ts are 12.9 in deep X 9.25 in high X 6.6 in wide.....I figure the deep has play and the plastic tray can surely handle .1 inch wider but the height but the 1.25 inch taller high maybe a problem????? My trailer is not home here so I can't measure the door opening/compartment size right now.
Kistler
Old 11-29-2004, 03:34 PM   #13
RoadKingMoe
Beavercreek , Ohio
Sorry guys... been off-line for a day or so. Yes, it would be a bit more tongue weight, but not much. I too am unsure about the Group 31 size. It would be so close that the only way I'd feel good about it would be actually cabling one up and trying to stuff it in there.
Maurice
AB8XA
WBCCI 5446
Old 11-29-2004, 03:39 PM   #14
RoadKingMoe
Beavercreek , Ohio
One other thing... AGMs can take a bit more voltage in the bulk mode, and need less voltage in the float mode. Ideally, one would upgrade the converter to something like the Inteli-Power with Charge Wizard, rather than keep the 13.8V single-stage Magnatek.
Maurice
AB8XA
WBCCI 5446
Battery Location uwe 1970-76 Tradewind 22 09-04-2003 08:44 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 06:19 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 02:03 PM
61 Bambi Battery 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 05-21-2002 11:53 PM
