Old 03-15-2009, 06:19 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Where's the 12Volt Fuse Panel 72 Tradewind
Blew a fuse on my 72 Tradewind working on the front door light. I've looked every where but haven't found the fuse box. I even have a manual with a photo of it and can't locate it. any ideas?
RichHog is offline   Reply With Quote
Old 03-15-2009, 06:22 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The fuse panel should be in the front of the Univolt. It should be located rear curbside under the curbside bathroom closet.
Old 03-15-2009, 06:35 PM   #3
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I'll check there. Looks like the PO put a new univolt or something in there just sitting on top of plumbing. Do you know what the fuse circuits go to? I have a manual but it just labels the fuse circuits as 1-4. Was working on getting the front door like working and it arced and took out the first overhead light as well.
Old 03-15-2009, 06:55 PM   #4
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Blown fuse on Tradewind
You're correct Lumatic, should have opened up the Univolt. Makes sense that it would be back there. Fuse 4 was blown.
Also have a Rapid Charger looks like was installed to charge the battery that was in there.
12v
Fuse panel question RandyG Batteries, Univolts, Converters & Inverters 2 06-10-2008 11:46 PM
Third wire on the fuse panel help flashbackk Batteries, Univolts, Converters & Inverters 9 05-01-2008 08:27 PM
fuse panel question BigSky Electrical - Systems, Generators, Batteries & Solar 6 02-26-2007 07:45 PM
Where is my 12volt fuse panel??? Blu_Hwy_Lady Electrical - Systems, Generators, Batteries & Solar 5 07-02-2006 12:37 PM
Fuse panel bluebonnet Electrical - Systems, Generators, Batteries & Solar 7 08-15-2004 10:42 AM
