01-27-2015, 07:52 PM
1979 31' Excella 500
Charlevoix
, Michigan
Where to position heavy batteries?
I'm in the process of renovating our '79 Excella 500 (31') and am wondering if I've designed the interior to have too much heavy stuff in the rear. My fear is that I'll design and build this beautiful camper only to have it sway all over the place when I'm going down the road because too much structural weight is beyond the rear axels. Specifically, I'm wondering if I should relocate the batteries and inverter (about 450lbs!) more toward the front of the camper. Here's a diagram of the way I have things laid out (not actually built yet, and this picture isn't my camper, just the same model):
I tried a couple different placements of the batteries and inverter, such as (and these are pictures of my actual renovation):
#1. Under and behind where the oven and stove top will be. Great position because it puts 450 lbs closer to the front, but not crazy about putting all the electronic so close to a heat source like an oven.
#2. Where a closet will be. Good position because it's 450lbs over the axles, so no bias toward the front or back, but not crazy about losing all the drawer space.
#3. Inverter (blue) is under where the oven will be, and batteries are nearby where a closet will be. Good position because it distributes the weight over the axels with no bias front or back, but not thrilled with the inverter being under an oven (heat) and losing the drawer space where the batteries sit.
#4. These 2 pictures are the same position, 1st is a view from the front looking back, and the 2nd is from the back looking forward. Batteries and inverter occupy and otherwise unoccupied space (no losing any storage with this position) but worried about putting 450lbs toward the rear of the camper, even if it is just right behind the axel (see diagram above).
If you were me, where would you place the batteries and inverter? Would you be OK with the #4 option (logistically perfect location, but adds weight behind rear axels) given the weight of everything else forward of the axels?
01-27-2015, 07:59 PM
1999 34' Excella
Hillsboro
I would 'split' the load starboard/port.... and definitely ahead of the front axle to maintain 'balance'...but if you are 'stuck' on one side I would choose the Street side.
Peace and Blessings..
Channing
WBCCI# 30676
01-27-2015, 08:04 PM
2020 Classic 33
Box Elder
, South Dakota
trekker aren't those Duracell's a flooded battery which will outgas potentially dangerous stuff when being charged? Safer with AGM's.
From the web.
Why is there a risk of an explosion?
When batteries are being recharged, they generate hydrogen gas that is explosive in certain concentrations in air (explosive limits are 4.1 to 72 percent hydrogen in air). The ventilation system can exchange an adequate amount of fresh air for the number of batteries being charged. This is essential to prevent an explosion. Also, no flame, burning cigarette, or other source of ignition should be permitted in the area.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
01-27-2015, 08:05 PM
1978 Argosy 24
MooreHaven
I think with your last photo you have the most logical location for the batteries,however with inverters that i have experience with if my memory serves me the instructions all said not to have the inverter in with the batteries as the batt fumes are corrosive and potentially explosive if some fault in the inverter was to create a spark.
This is only temporary unless it works! Red Green
01-27-2015, 09:32 PM
1974 Argosy 20
Kooskia
, Idaho
What you want is the total trailer to be in balance and we have no way of knowing what else you are putting in and where it will be. If the batteries are at the axle location you have a net neutral for them but if they are behind the axel and you have something else in front of the axle (say a refrigerator) they may well counterbalance out just fine. Now a huge weight at the back balanced by a huge weight at the front is not good for the frame, but think of you total design as one unit, not each piece as individual items.
01-27-2015, 09:50 PM
1999 34' Excella
Hillsboro
AS idroba states.. your 'heavy' stuff should be nearer axles.. and lighten as you move toward bow/hitch.
Minimize weight AFT of the axles.
Channing
WBCCI# 30676
01-27-2015, 11:11 PM
New Borockton
, Alabama
How long do you plan to boondock? Most think a week or so and find shore power within a couple days and others REALLY need the batteries.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
01-28-2015, 01:35 AM
Vintage Kin
Fort Worth
Very nicely done with diagram, pics and text!
Athwart the axles and slightly forward to help TW. It really is a lot of concentrated weight for a TT.
I, too, would be in favor of fewer batteries in this as per use and as caution.
FWIW, I've learned I can load a 52' x 102" flatbed with [11] 4,400-lb pallets of bagged material where -- with most of the weight over the axles front and rear -- the single line of three down the center causes steering change if off by three inches.
Your problem to solve is worse.
01-28-2015, 05:42 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Having worked in an industry that uses the typical deep cycle batteries that most of us have in our AS I would never put them in an enclosed area, especially near an appliance that uses and electronic start or has an open flame. When batteries are charging or are over charged or heat up they emit Hydrogen Sulfide, which given the right circumstances can be a serious fire hazard, also tough to put out. I've seen entire golf car storage facility burned to the ground in a short period of time due to one bad battery exploding out of 240 in the golf cars. The fire marshal pinpointed the exact cause and location of the offending battery.
I might instead configure something on the tongue or rear as a new battery compartment.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
01-28-2015, 07:07 AM
Charlevoix
, Michigan
Thank you everyone for your replies! Here are my responses:
Yes, they are flooded. Don't worry, once installed, I'll vent them externally.
Originally Posted by oldiesel
...if my memory serves me the instructions all said not to have the inverter in with the batteries as the batt fumes are corrosive and potentially explosive if some fault in the inverter was to create a spark.
You're right. When I actually build the battery box, the batteries will vent to the outside and the inverter will be in a separate, but nearby, compartment.
I planned the electrical setup for about a week of boondocking before needing to go plugin somewhere. We'll have a generator to supplement, and solar in "stage 2" of renovations about 2 years from now. I'll be both living and working from our AS when we go full time in 2016, so I want to make sure we don't have to cut the fun short because Daddy needs to charge his laptop.
I guess what I really have here is a physic balance and weight problem to solve; should have paid better attention in school!
01-28-2015, 07:59 AM
Charlevoix
, Michigan
Downloaded some physics software from the App Store and created a little simulation with proper weights, lengths and positions on the trailer (see attached video). All the little boxes represent the items noted in this diagram:
Looks like the trailer still falls forwards (see attached video). Next step is to ensure 10-15% of the total trailer weight is on the tongue. Haven't figured out how to calculate that yet.
01-28-2015, 08:25 AM
1982 31' Excella
Rochester
, New York
Treker, Did you do a shell off for the floor replacement?
01-28-2015, 08:29 AM
1964 26' Overlander
Richmond
, Virginia
I set mine opposite the fresh water tank. the idea being that when I left for a trip, the fresh water tank and the batteries both are right over the axles. My gray tanks are right below these. Everything is pretty much between the 2 axles. Since I removed all the heavy stuff from behind the axles, (the original battery and converter) then that left the remaining weight from stove, propane tanks, and other items up front. When we drive, I put suitcases and duffel bags on the floor in front of the goucho. That keeps them from sliding or falling off of anything if we have a sudden stop, and we still have a path to the toilet in back. That also helps increase the tongue weight a little.
Just the way I did it.
01-28-2015, 08:35 AM
Charlevoix
, Michigan
Fortunately I did NOT need to take the shell off the replace the floors.
01-28-2015, 12:50 PM
Dallas Center/Des Moines
, Iowa
It occurs to me that if you duplicate the factory spec tongue weight you will be pretty good.
01-28-2015, 12:57 PM
, Iowa
Try to duplicate factory spec for tongue weight.
A Sherline scale will be exactly what you need.
http://www.sherline.com/lm.htm
01-28-2015, 02:32 PM
1975 31' Sovereign
Palomar Mountain
Have you thought of placing the batteries under the refrigerator? This would:
1. Raise the refrigerator up so you don't have to bend over to get stuff out of the bottom shelf (as done on later model AS's).
2. Move the weight forward directly over the front axle.
3. Still have storage under the refrigerator toward the front.
Also: Use AGM battries:
1. Cost the same per year (they last longer).
2. No fumes to worry about - no 'battery box' or outside venting with it's ducking.
01-28-2015, 07:46 PM
Charlevoix
, Michigan
This is a great idea in my situation; I hadn't even considered that but it makes perfect sense to put the batteries and inverter under the fridge. I already have the lifted fridge in my design plans (see attached image) so all I have to do is run the wiring where it comes up from the floor behind the axels to the front of the axels where the fridge is located.
Thanks for the idea Silver Hawk!
01-28-2015, 08:14 PM
Vintage Kin
Fort Worth
But what will you place across from that to offset?
In mine the reefer is starboard atop the furnace and across from the washer/dryer plus pantry. Just off axle dead center. The reefer and W/D each weigh 120-lbs and the pantry weight plus goods easily offsets the furnace weight.
01-28-2015, 10:05 PM
TommieDee54
2013 30' Flying Cloud
Clayton
, Georgia
My 30ft Flying Cloud is set up with 4 Lifeline 6 volt AGMS batteries, total amps:880, total weight: 264#, no venting needed! I have a Magnum MS 2000 Inverter. I haveThese GPL-4CT batteries will last years verses the old style! Another issues is to keep the inverter and batteries as close together as possible,more efficient, less loss of voltage. Most of the installation I've seen, including my trailer with a forward couch or bed is to place the system underneath, then run shore power to the inverter and then back to the distribution( breakers, fuses)point. This setup keeps all the weight forward of the axles, yet 4ft to 10ft behind the hitch, centered left to right and easily accessible. This setup tows great. I also use a Hensley Hitch. You also have room for a solar panel controller.
