You clearly want a fuse or circuit braker installed before the monitor and close to the battery positive. Any electrical device in the trailer should be fused. This is especialy true in an all metal chassis. If you feed wire to any electrical devise ever cuts through the insulation and touches the framework of the trailer you got a problem. Fire is not a major risk but attemping to rewire through an Airstream chassis is a problem.
2004 Excursion 4x4
