Old 06-24-2012, 11:03 PM   #1
CF Av8or's Avatar
1973 29' Ambassador
East Lawrencetown , Nova Scotia
Where the heck is the 50A fuse in a '73 Ambassador???
Okay, I've searched the '73 Airstream operator's manual and the 73 factory shop manual and no where does it give the slightest hint where I would find it.
On my 1973 29' Ambassador with rear bath, everything works fine on 120V shore power but I get nothing on battery power. I'm sure this fuse is the culprit, but I can't see it and I don't know where to look for it.
The schematic shows it between the battery and the Univolt, but the wiring is concealed behind all manner of non-removable obstacles. Can anyone tell me what I have to dismantel to get access to this fuse??
Thanks.
Vic
Vic Ruzgys
1968 Chevrolet C-20
CF Av8or is offline   Reply With Quote
Old 06-24-2012, 11:20 PM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
near the battery
Thanks.
Vic
Vic,
It is near the battery as a in-line setup. It is a single fuse in a black plastic holder mounted on a small piece of wood. Follow the ground wire from the battery. It is a ground fuse.
As hard as it is to get out of it's holder, you need to take it out of the holder to test it.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 06-25-2012, 03:12 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Vic,
I don't know if your 73 Amabassador is similar to my 75 Sovereign. However the access to the fusses on mine was obtained by lifting up the closet floor and through a small access panel in the curbside closet just ahead of the tub. On mine the Univolt is actually under the bath tub.
Aaron
WBCCI #XXXX AIR #2495
Old 06-25-2012, 04:24 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have found them in a ceramic fuse holder screwed to the floor in the back of a closet similiar to the post above, That was in a 72 or 73 safari.
You need to physically follow the negative battery lead until you make it all the way to body ground.
There does not seem to be a lot of consistency in the way these were done
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
HWH Leveller - where is the 15 amp fuse? Boom Sounds Mechanics Corner - Engines, Transmission & More... 3 09-22-2011 07:14 PM
Ambassador :: 1971 Airstream Ambassador nascar427 Airstream Registry Discussions 0 08-19-2011 10:07 PM
Ford fuse panel 95cutterbus Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 06-26-2011 06:38 PM
50 AMP fuse on Neg or Positive Pinchy Batteries, Univolts, Converters & Inverters 16 05-29-2011 07:56 AM
Water Stains on Ambassador? MATTY J Cleaning, Stripping & Polishing 6 05-01-2011 08:28 PM
