10-20-2011, 10:05 AM
bearden
, Arkansas
Where is the inverter?
I just bought this 74 soverien rear bath 31' I need to get to the inverter and fuse box but don't know were it is I hope some one out there will not think this is a dumb question and HELP !!! me please
Tom
10-20-2011, 10:24 AM
1974 Argosy 20
Kooskia
, Idaho
I doubt that you have an inverter, they convert 12 volts DC to 120 AC. You will have a converter charger that makes 12 volts to run the lights etc from 120 volts shore power. It also charges the battery. They were located in various places in the Airstreams, but you might try looking under the couch in the front of the rig. The fuses may also be there, in a panel covered by a plastic part, right under the front window. It should indicate that there are fuses inside.
If not, plug the rig in, and listen carefully for a humming sound somewhere in the trailer. That will be the "buzz box" original converter/charger. Fuses will be nearby.
10-20-2011, 10:46 AM
Retired.
, At Large
Welcome to the forums. If your Sovereign is a rear bath model, the CONverter is under the bathtub, and can be accessed through the curbside closet. Your trailer may have a switch inside the bathroom vanity behind the mirror to turn the Univolt on and off.
10-20-2011, 10:59 AM
Alamo Heights
"Where should I put this box of electronic circuitry and fuses?"
"Hmmm... put it under that big tub for water with plenty of plumbing nearby."
Sounds like design work done at/after Happy Hour.
— David
10-20-2011, 09:34 PM
New Borockton
, Alabama
Funny DKB! Terry is right and Airstream is not alone on this. I can't tall you how many folks call in about water dripping on the converter.
Tom, Terry is probably correct but also look under the sink, behind the stove/oven and under the goucho. Its there somewhere and probably humming like a barber.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
10-24-2011, 09:27 AM
1984 31' Excella
Lees Summit
, Missouri
Would the converter also make a hotspot in the floor behind the couch near the charger switch??
10-24-2011, 09:31 PM
New Borockton
, Alabama
Yes
Some do
888-828-1893
Bestconverter.com
10-25-2011, 09:33 AM
1984 31' Excella
Lees Summit
, Missouri
Thank You,
What model AS was this in. Looks dangerous.
Jerry
10-25-2011, 11:49 PM
New Borockton
, Alabama
Thank You,
Jerry
I don't remember what model Airstream or even if that was an Airstream. It was sent to us a few years ago and recently we have more pics burning the carpet and another burning the plactic cover over the carpet that manufactures put down. I'm still baffled on Airstream using these but I'm not affiliated with them. They like Parallax single stage units clearly.
888-828-1893
Bestconverter.com
