Old 08-29-2011, 09:25 PM   #1
Maggiefoss's Avatar
2000 25' Excella
Danville , California
Where is the AC/DC switch on a 71 AS Trade wind?
Hi,
I am fairly new to owning an Airstream, so this might seem like a dumb question. I have only used it at parks where I have an electrical connection. Now over labor day I am camping on the beach without any hookups. Is there a place that I switch my trailer over to using battery?? The reason I ask is, in ,my old 65 shasta trailer, there was a Ac/DC switch in the closet, so depending if you were plugged in or not you switched to what you were using. Do I do this in the airstream?? I can'
t seem to get electrical on unless I'm plugged in. Thanks for your help.
Maggie
Maggiefoss
Maggiefoss is offline   Reply With Quote
Old 08-29-2011, 09:31 PM   #2
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Got to ask - you do have a charged battery in the camper, right? If so there should be a switch by the battery that turns on the 12 volt systems powered by the batery. You will not be able to use the 120V outlets but can turn on the 12 volt lights and radio, fan, etc. Fridge should be on gas, No AC, etc.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-29-2011, 09:40 PM   #3
Originally Posted by Maggiefoss View Post
Hi,
Maggie
Airstream never installed such a switch.
Old 08-29-2011, 09:49 PM   #4
Maggiefoss's Avatar
2000 25' Excella
We just drove it back from where i store it, so it got charged about 2 hours worth of driving. I just went out there and I could turn on the overhead light. My guage said battery very low (on the overhead console over the front couch) I think my battery is in its own compartment by the right rear tires, is that correct??
Maggiefoss
Old 08-29-2011, 09:58 PM   #5
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Not sure where in that model. Two hours drive will not charge a low battery - even a long 6 hour drive may do a moderate charge to a battery through the umbilical, just not the best way to charge. Plug in or use a dedicated charger direct to the battery (generator) or have solar to charge during the day. When on battery you must be very careful of power use and how far you draw down a battery.
Old 08-29-2011, 10:20 PM   #6
Maggiefoss's Avatar
2000 25' Excella
Thanks, I just read in the manual (when in doubt start looking in the manual....) that the trailer will use the battery power when not connected to 120 volt. so it just happens automatically. It also says to keep it connected to the 120 volt to charge the battery to full power. I was just confused because of my last trailer having a switch. thanks for your help!!
Maggiefoss
Tin Pickle :: 1971 Airstream Land Yacht Trade Wind webspinner Airstream Registry Discussions 1 03-05-2014 05:17 PM
The Q.E. III :: 1962 Airstream Land Yacht Trade Wind tlsmit1 Airstream Registry Discussions 1 05-23-2013 01:56 PM
1968 Trade Wind 24 Double Project TeamD 1959-69 Tradewind 17 03-08-2012 06:45 AM
Aluminati :: 1963 Airstream Trade Wind Grand Master Airstream Registry Discussions 0 08-19-2011 08:30 AM
1977 Trade Wind hubcap? Dastardly Wheels, Hubs & Bearings 3 04-04-2011 05:42 AM
