Old 05-19-2017, 05:57 PM   #1
Continents Collide
1985 32' Excella
Spring , Texas
Where are my 12v fuses?
So. I was about to buy my converter from randy at best converter and he recommended upgrading my fuse box from my original. I have a 1985 excella.
I went back and looked through all my pictures and remembered that in doing my renovation, I had looked for my 12v fuses but never found them. In the midst of doing plumbing, propane and everything else I had forgotten to find them.
So. I need your help.
My 120v is at the back in the overheard storage.
Here is my apparent fuse box at the front under the main windows.
Name:	2016-12-17 14.05.24.jpg
Here is the original univolt. Doesn't look like there are any fuses on the unit and no flap to lift up?
Name:	2016-11-06 12.25.50-1.jpg
Someone I talked to mentioned maybe the PO did a botch job and took out the fuses?
Name:	2016-11-17 19.07.12.jpg
Thoughts?
continentsco is offline   Reply With Quote
Old 05-19-2017, 06:11 PM   #2
Long Island , New York
Do you have the owner's manual? This online manual from Airstream may cover your AS -- not sure. Coincidentally we had a 1985 25' back in the 90's!
https://www.airstream.com/wp-content....085c.arc_.pdf
The Electrical System starts on page T-1. [PDF p. 66/80]
On p. T-2, it says the 12-volt circuit breakers automatically reset.
On p. T-3 at the bottom, the diagram indicates that your 12-volt panel is in the front. Those fuses [circuit breakers] are -- IMO -- included in the panel you show in the first photo, and they reset themselves per p. T-2 sentence above. The diagram on p. T-6 shows the amperage for each 12-volt circuit in this panel, and it looks like yours in the first photo.
If the above manual is not the right one, you can check others at the main Airstream site, under the "Service" menu item at the top right, and "Manuals" in the drop down menu.
Although this manual refers to a Service Manual regarding electrical problems, I can't find such a document.
Good luck!
Peter
Old 05-19-2017, 06:35 PM   #3
PS -- one other thread on similar panels and idroba [RIP] on replacing the panel, and on resetting circuit breakers FYI:
[click on arrow in quote to go to that thread]
Originally Posted by idroba View Post
There probably is no real great reason to replace it. That said, I am not a big fan of automatic reseting circuit breakers as if there is a real dead short, they simply sit there and try to reset, over and over and over until they fail or the power system is compromised. I kinda like fuses, they blow and you know you have an issue. They stay off until the problem is corrected.
Old 05-19-2017, 06:46 PM   #4
1986 31' Sovereign
Miami , Florida
The two lug aluminum boxes with the black bottoms are auto resetting circuit breakers.
On my 86 Sovereign, I simply removed the old converter, installed the new Progressive Dynamics version. Attached the DC output lines and plugged it in. All there was to it.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-19-2017, 09:21 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
That breaker box looks good to me. I see no reason to change it out. I have the same in my trailers. I have changed out the converter in both trailers and left the same breakers and used the existing wire. Plug and play, easily less than a 30 minute install.
I would not switch to fuses even if there was a problem with the breaker box. If I had to replace the panel mine I would replace it with another breaker box. I have had a few beakers go bad over the years, one or two in 25 years of owning Airstreams.
Alan
Old 05-19-2017, 10:29 PM   #6
Continents Collide
1985 32' Excella
Spring , Texas
Awesome. Thanks. Ordering the converter tomorrow!
Old 05-19-2017, 10:29 PM   #7
Continents Collide
1985 32' Excella
Spring , Texas
Thank you!
12v
Fuses vs Circuit Breakers for 12v Protection? dbj216 Batteries, Univolts, Converters & Inverters 19 04-04-2016 12:50 PM
location of 12V breaker fuses GatorDave Jacks, Stabilizers, Lifting and Leveling 8 04-02-2016 12:24 PM
Fuses, what fuses? safariuser Electrical - Systems, Generators, Batteries & Solar 8 04-06-2015 05:52 AM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
