Old 09-26-2015, 06:30 AM   #1
2013 25' International
mont st hilaire , Quebec
When i park my tt and my suv ....
Hi
I park my TT for a week when I make a cruise
When I come back my suv have a little problem to stat not a strong power in the battery but finish to start ..... never beford..
I dont have any solar pannel in my tt and the fridge is one for the week
I don't know but may be the problem is I din't unplug the TT from my suv
is it possible the power from the battery go for the fridge ???
Is't better to unplug the TT from my suv or not ???
thank you
socool69 is offline   Reply With Quote
Old 09-26-2015, 06:34 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
You are using the battery from your SUV. When you park, disconnect the Airstream. Some SUV have this automatic disconnect. Yours must not. Many have used all their SUV
battery power overnight with lots of usage. The next morning they are stuck with a dead battery.
Old 09-26-2015, 06:56 AM   #3
2015 30' FB FC Bunk
Ayer , Massachusetts
Does the TV have a relay disconnecting the power? Check the manual.
Ted S. is offline   Reply With Quote
Old 09-26-2015, 07:51 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would check what else may be running in the trailer. The frig on gas should not pull the trailer and TV batteries down in a week.
When batteries are connected in groups, 2 or more, they have to be of the same size and condition. If not one battery will try and charge the other to it's voltage. I suspect your trailer and TV batteries are not. Another thing to check is the condition of the batteries, TV and trailer, with a hygrometer. Imbalance is not good. You can run on the road with this condition because the alternator will stay ahead of the problem but when parked things don't last long.
I would run an experiment at home of running the frig on the trailer batteries and see if they will last for a week. If you just do this on the road you run the risk of the frig shutting off while you are gone.
2004 Excursion 4x4
Old 09-26-2015, 01:33 PM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
The frig and gas detectors will almost kill my batteries in 12 days....
Old 09-26-2015, 01:40 PM   #6
HowieE's Avatar
Images: 12
I would check the batteries with a hygrometer to see if one has a bad cell. That load is only milliamps.
2004 Excursion 4x4
Old 09-26-2015, 01:43 PM   #7
ColoradoLady's Avatar
Disconnect your 7Pin when not using TT. IT WILL MOST SUREDLY DRAIN SUV via trickle charge from TT.
ColoradoLady is offline   Reply With Quote
Old 09-27-2015, 06:48 AM   #8
need to unplug for sure and may be my batteries
thank you for all your ideal
2016 Ford 250/350 SUV conversion. Guess I can have my cake and eat it... Danattherock Tow Vehicles 27 07-14-2015 02:10 PM
SUV and 34ft AS? instax Tow Vehicles 10 04-01-2014 10:19 AM
Need help picking a trailer and SUV to tow with joevandyk Our Community 6 11-06-2011 11:00 AM
SUV's and generators Don Cook Generators & Solar Power 21 03-23-2007 10:01 PM
Towing a small 60s trailer with a SUV... Andy R Tow Vehicles 15 03-30-2002 07:57 PM
