Old 09-29-2016, 11:06 PM   #29
1973 31' Sovereign
Middletown , California
When I make golf cart cables or other battery cables I smear lots of rosin flux on the wire and inside the terminals before crimping. Then I heat the assembly and flow solder into the terminal until I'm sure that all the flux has been displaced and the area has no space that corrosion can occupy. I try to make the copper cable one with the terminal so to speak. Then I clean off any left over flux with a toothbrush and isopropyl alcohol. I have seen many connections that look good but are corroded inside. Checking for voltage drop or heating while heavy current flows will tell if the connections are good.
ijustlee is offline   Reply With Quote
Old 09-30-2016, 05:50 AM   #30
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Next time you take the cables off, use an ohm meter to check the resistance in each individual cable. Should be zero-- 1 or 2 maybe. More than that, there's a connector problem.
mimiandrews is online now   Reply With Quote
Refrigerator thermostat readout - wrong wrong wrong BoldAdventure Refrigerators 12 09-18-2015 05:02 PM
Buck rivets look wrong?using wrong air hammer bit? shadeemry Ribs, Skins & Rivets 11 06-07-2014 07:42 PM
HELP with Brakes- Wrong TV? Wrong AS? Flying Gypsies Brakes & Brake Controllers 7 07-24-2011 07:04 AM
Cold weather battery bank maintenance Boondocker Generators & Solar Power 16 12-22-2007 10:23 PM
Battery Bank Tarheel Batteries, Univolts, Converters & Inverters 19 03-06-2004 01:48 PM
