Old 11-22-2006, 09:23 AM   #1
2007 25' Safari FB SE
Suburbia , Sunny So Cal
What's this do? Battery wire
There is a wire that runs between my batteries from pos to pos terminal. Whats it do and is it required? No its not the cable but a smaller wire.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 11-22-2006, 09:29 AM   #2
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Hi Milo; It's a goesintothe; you know goes from one post into the other! Doesn't make mind to me, You already have the heavy gauge there correct? Redundancy in a AS. got wings?
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 11-22-2006, 09:44 AM   #3
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
it is probably a jumper wire to charge the motor batt and or the camper batt when in vehicle driven mode or on univolt mode.both batts are grounded to the same ground some where in the electrical system..
bobchevy89 is offline   Reply With Quote
Old 11-22-2006, 10:57 AM   #4
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Its a service road to the main highway.
klattu is offline   Reply With Quote
Old 11-22-2006, 11:19 AM   #5
I'm surmising from what you guys have said that it's not an important componant. I was interested because my new batteries (Optima) don't have those side post dealies.
So I can merrily hook up everything to the posts and be on down the road without a battery worry?
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 11-22-2006, 01:13 PM   #6
Pahaska's Avatar
Hays County , Texas
That is strange because the cables from the 2 batteries each connect through a separate automatic-reset circuit breaker in the terminal block. A wire between positives would parallel the circuit breakers rather than each one handling its own battery. I see no electrical requirement for such a wire.
I want my batteries as isolated from each other as possible. For that purpose, I installed extra switches so that I can use one battery at a time. Single batteries charge better and with my switches, I can select one battery at a time and prevent an accidentally left-on load from completely draining my batteries when boondocking. I also use the switches to charge only one battery at a time while in storage. I swap the charge to the other battery every Sunday morning when I make my weekly check of the trailer.
John W. Irwin
WBCCI #9632
Old 12-10-2006, 04:17 PM   #7
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Milo: I've been tearing into my electrical system. Guess what, The PO installed a solar panel to charge the batteries and a perko batt switch. There is a 10 gauge wire connecting the + terminals.Appears the solar panel will not charge without a path to the batteries(do ya think?)Anyway without having x-ray vision that's where I stand. SO do you have solar panels? I do not recall seeing one on your most elegant AS. Tim
www.popasmoke.com
YETI ( 65 Quart )
Old 12-10-2006, 05:18 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
Milo -- I guess your thread has been hanging for a while. I don't see that you've gotten a specific answer to your question yet. The jumper between the positive poles and the jumper between the negative poles is the OEM wiring in parallel; the output is still 12 volts. The one black wire that heads forward from the near positive pole is what powers the electric hitch jack.
Attached is a photo of my '06 Safari that I took a year ago so that I'd get everything put back in there the way it came out. I can't go out to storage to recharge every month and don't want parasitic load draining them in cold weather, so I take them out and maintain them here at home.
Tim -- I hadn't seen this thread before. Thanks for remembering it was out there!
Name:	Oct 2005 Batteries.jpg
5 meter Langford Nahanni
Old 12-11-2006, 12:30 AM   #9
O.K. I'll admit it. I'm a moron
I had posted my question from memory as the Unit is elsewhere. I went out and got my new batteries and when I went to install them....The electric hitch wire is long and laying partially on top of the batteries. Somehow in my addled brain it seemed to be another connection. In fact the picture above is exactly what I have. P.S. Tim that frig fan you recomended works great!
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 12-11-2006, 08:34 PM   #10
WayWard Wind's Avatar
2004 25' Safari
Just in case
you may want to check just where that power wire to the hitch clears the the front of the battery box, on it's way to the hitch motor. There is a fuse holder located there for the power hitch and in my case was very difficult to find in the darkness of the night. For whatever the reason, mine decided to blow and was very difficult to find because it was hidden by the LP bottle.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 12-11-2006, 09:07 PM   #11
Good idea -- I'll look a little deeper in the spring. Thanks!
Old 12-12-2006, 06:05 PM   #12
Best,
After Mrs. Goin camping blew that fuse the third time..... I can do it in the dark blindfolded.
If you hold the switch after the leg retracts fully. It blows.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 12-12-2006, 09:08 PM   #13
TIMEMACHINE's Avatar
Huntington Beach , California
Really
Goin camping - I am in big trouble because of you..I tried retracting Mrs Timemachines leg and all I got was a slap on the head...then I figured out that you were refering to the AS. Once again...dohhh!
TIMEMACHINE is offline   Reply With Quote
Old 12-13-2006, 08:45 AM   #14
I told you. If you try to retract a leg a fuse blows. LOL!
WBCCI 6731 FCU
AIR# 13896
CA 4
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Battery Slide Out niftypkg Electrical - Systems, Generators, Batteries & Solar 5 01-01-2003 03:41 PM
Second Battery w9det 1999 Safari 5 12-06-2002 06:42 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
