Old 10-08-2016, 11:16 PM   #15
1987 25' Sovereign
Richland , Washington
Well I received my PM4B-60 PowerMax from Randy (in two days instead of three) and installed it no problems. Randy answered a couple questions I had right away. I also installed my new group 31 Duracell batteries. Verified with my DC clamp on ammeter that the initial charge (about 14 A) tapered down after less than an hour. I also replaced my old tongue jack that was slowly dying - although the new converter and batteries did breathe some new life into it. The PM4B-60 PowerMax is silent and cool. The fan never did kick on so I got bored and reinstalled the gaucho coucho and called it a day.
Next electrical upgrade will be LED lights - I found my old automotive style bulbs are drawing 1.5 A each!
JohnBarth is offline   Reply With Quote
Old 10-09-2016, 02:42 PM   #16
New Borockton , Alabama
Images: 21
Thanks John. FYI the part numbers on the Boondockers have been changed to make it easier to understand the models. For example the PM4B-60 is now simply BD 1260 (12 volt, 60 amps) etc. Many have inquired so thought I would clarify here. There might be a few of the old part numbers floating around but there is no difference.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 03:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 03:59 PM
Converter size revisited PeterH-Airstreamer General Motorhome Topics 3 06-07-2012 06:29 PM
converter size lahrfarm Batteries, Univolts, Converters & Inverters 10 02-20-2011 07:52 PM
Wire Size, To Converter Dan Clayton Batteries, Univolts, Converters & Inverters 8 06-28-2007 11:22 PM
