Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 09-16-2007, 09:58 AM   #1
6 Beach rats
Profile:  1983 31' Excella
Churchville , Pennsylvania
What pwr.supply can I plug into?
Hello,
I have a 1983 Excella 31' I am new at this and need some advice. Tha power plug on the trailer I plug into campgrounds looks like a heavy 220v plug with a adapter to 110v, when I bought this it had the adapter hooked on so I have been only using the 110v not to mess anything up ,but when I turn on the A\C it draws too much power and will not work great. my question is can I use this plug without the 110v adapter and plug into higher pwr., amp.,220v? Please any help will be great as I am leaving for Hatteras in 2 weeks! Glenn
6 Beach rats is offline   Reply With Quote
Old 09-16-2007, 10:08 AM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Glen,
Welcome to the Forums
Can you post a picture of your plug? I have never seen an Airstream with a 240VAC set-up. Plus, the only RV's that use a 240VAC plug are the bigger MoHos and 5th wheels that use a 4 prong 50 amp plug.
What you should have is a 3 prong 30 amp 120VAC plug that is RV-specific.
A picture is worth a thousand words though. You might check it by seeing how the umbilical's wires are connected into your AC breaker box. If the black lead goes to the hot bus (breakers), white goes to the neutral bus and the green or bare wire to the ground bus, then you have a 120AC set-up.
Keep us posted.................
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 09-16-2007, 10:09 AM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
The plug on your trailer is most likely a 30 amp 110 volt RV plug. You should be fine plugging it into an RV Park outlet. The plug should look like this:
An adapter like this:
allows you to plug into a 15 amp outlet.
It does not convert 220 to 110.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 09-16-2007, 10:32 AM   #4
6 Beach rats
Thank you ,thank you, thank you,
Thats it , I thought the plug was 220v,being so much bigger and heavy guage. Question well answered, A+++++ Thanks , Glenn.
Old 09-16-2007, 10:41 AM   #5
amitchell
amitchell's Avatar
Profile:  1972 27' Overlander
Dallas , Texas
Greetings, Glenn
I just bought my first Airstream a couple of weeks ago. I asked a similar question, and got some very helpful responses... (click on link below)
My "New" 1972 Overlander
amitchell is offline   Reply With Quote
Power supply ? starflyte1 Batteries, Univolts, Converters & Inverters 4 03-19-2007 08:29 AM
LP supply line uwe LP Gas, Piping, Tanks & Regulators 8 09-17-2006 04:12 PM
switch for 12v supply to refrigerator nickcrowhurst Refrigerators 11 02-09-2004 02:33 PM
New LP Supply line? themostbob LP Gas, Piping, Tanks & Regulators 0 05-01-2003 09:35 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
