Old 03-31-2010, 04:30 PM   #1
jagzoo's Avatar
2009 25' FB International
Wilmot , New Hampshire
Images: 8
Question What outlets are available when using battery power?
We have a 2009 25FB International Airstream trailer. I know our dealer told us this, but we can't remember and can't find it written anywhere. Is there an outlet that supplies 110 power when on battery? I know that the TV works on battery. We will be traveling out West where we will mostly be staying in National Parks and other Federal lands without electricity. If there isn't such an outlet then we need to know to bring an inverter for our computer.
jagzoo is offline   Reply With Quote
Old 03-31-2010, 04:47 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Only if you have an inverter.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-31-2010, 04:59 PM   #3
jagzoo's Avatar
Images: 8
Hi Mello Mike,
We do. It was part of the original equipment.
Old 03-31-2010, 05:04 PM   #4
jagzoo's Avatar
Images: 8
If it makes any difference, it is a 600w inverter.
Old 03-31-2010, 05:09 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
To have a 110 volt outlet operational while not on shore power, it would have to be one powered by an inverter unit installed in the trailer. If there is such an outlet, it should be clearly marked as such. Depending on the wattage of the inverter unit, this could run down your batteries pretty quickly. Some televisions can run on 12 volt with their own built-in inverter.
Brian
SuEllyn & Brian McCabe
Old 03-31-2010, 05:15 PM   #6
moosetags's Avatar
The 600 watt inverter will put our 5 amps.
Brian
Old 03-31-2010, 05:18 PM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by jagzoo View Post
Hi Mello Mike,
Okay, if you had an inverter installed when you bought the coach then it could be wired in one of two ways:
1. Providing power to a single 110v outlet.
2. Providing power to all 110v outlets.
My Freedom 10 1000w Inverter provides power to all my 110v outlets.
1958 Overlander
4CU 1st VP
Old 03-31-2010, 05:20 PM   #8
moosetags's Avatar
jagzoo,
You posted this thread twice. I have deleted the other one.
Brian
Old 03-31-2010, 06:19 PM   #9
jagzoo's Avatar
Images: 8
Thanks everyone,
Obviously, the smart thing to do it to just disconnect shore power and test!! Guess I could have thought of that before. I'll let you know how Airstream wired it.
Old 03-31-2010, 06:37 PM   #10
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Only the TV outlet is powered
jkcru is offline   Reply With Quote
Old 03-31-2010, 06:39 PM   #11
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We have a 2006 19 Safari SE. My guess is that your factory inverter will provide to some but not all outlets, but I don't know that for sure. We have a factory 600w inverter alss...and there are separate receptacles for use when running on the inverter. In our unit we have two inverter outlets...one under the dinette table and one near the TV and cable/satellite incoming lines. Where they are located in your model will most likely be completely different.
TB & Greg and Abbey Schnauzer
#3954
Old 03-31-2010, 06:49 PM   #12
jagzoo's Avatar
Images: 8
That sounds like what I thought the salesperson said. I'll check tomorrow.
Old 03-31-2010, 07:48 PM   #13
CanoeStream's Avatar
St. Cloud , Minnesota
Awesome tow vehicle in your avatar pic, jagzoo.
We have a 100 watt inverter that plugs into a cigarette lighter on my truck (try Amazon or Radio Shack). It's the size of half a brick and fairly lightweight. I use it to recharge my computer or camera. I recharge when we're underway or running into town or wherever.
I baby the batteries on my Safari. I have a couple LED lanterns for after dark inside. I'll need everything the batteries have to run the furnace fan if it's getting cold at night. Try to develop an understanding about what it takes to avoid discharging lead-acid batteries much lower than 45% (eg, see this chart). I got 4.5 years off the first pair and am finally replacing them this spring. I can do some email and AIR Forums at night -- but no DVD or hulu action. That's what campfires are for.
5 meter Langford Nahanni
Old 03-31-2010, 08:47 PM   #14
jagzoo's Avatar
Images: 8
THanks CanoeStream,
Boy, don't we wish we could use "GOTSMRT" as a tow vehicle! I even wish we could load her onto our truck bed and take her with us.
Your suggestion to use the inverter off the truck battery to save the trailer batteries when we are dry camping for any length of time is a good idea. I do have a 100 watt inverter like that.
Thanks for the suggestion. Also, thanks for the chart.
No battery power wallybyam Batteries, Univolts, Converters & Inverters 6 01-25-2010 04:26 PM
Battery Power/City Power Question on Early 60's Airstream 63cloud Batteries, Univolts, Converters & Inverters 0 09-04-2009 08:07 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
No Power from Battery John Sims Batteries, Univolts, Converters & Inverters 5 08-01-2006 12:02 PM
battery power aeriqua On The Road... 9 02-09-2006 10:46 AM
