Old 10-27-2010, 04:47 PM   #1
coairstream's Avatar
1988 34.5' Airstream 345
Denver , Colorado
What kind of inverter/power supply should I buy?
I have a 1972 Tradewind that has to old school univolt? What kind of inverter/power supply should I buy? The most bang for the buck?
Thank you,
Cody
Cody
coairstream is offline   Reply With Quote
Old 10-27-2010, 05:01 PM   #2
1986 31' Sovereign
Miami , Florida
I believe what you are asking about is a converter (what the old Univolt was). Using 115VAC a converter produces 12VDC for lights, appliances and to charge the batteries.
An inverter is, essentially, the opposite -- uses 12VDC to produce 115VAC -- handy to watch tv, use the satellite receiver... when boondocking.
I have a Progressive Dynamics unit with the built in "Charge Wizard". I have the 60 amp unit which meets all of my needs. The Charge Wizard simplifies battery maintenance -- it won't overcharge your batteries and has a a mode that helps with sulfation.
I am sure there are other equally dependable units out there as well.
mike
Old 10-27-2010, 06:30 PM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I have an Iota that I purchased from Randy at Bestconverter.com. He is a member of the forum and has a lot of good information on his site. It's worth the electrons to check out.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-27-2010, 06:40 PM   #4
munimula's Avatar
1993 34' Excella
1962 16' Bambi
New Haven , Connecticut
inteli-Power
I have the Intili-Power in both of my rigs. Very pleased. If you go this way I highly recommend the Converter Status Remote Pendant. See...
intelipower - Google Product Search
Morrison's Airstream Page
munimula is offline   Reply With Quote
Old 10-27-2010, 07:22 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I installed an Inteli-Power 9245 with the Remote Pendant in my Trade Wind a couple of years back. I like it and my battery likes it too.
Richard
Old 10-28-2010, 01:27 AM   #6
New Borockton , Alabama
Images: 21
Cody,
Any multi stage unit will be MUCH better than the univolt including the the Parallax units that airstream has used for years. Look for anything 3 or 4 stage (4th stage being a silly desulfation mode that does little) with the exception of Iota that at least does a full charge cycle during storage every week.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 12-01-2010, 05:18 PM   #7
Ag'71's Avatar
1971 27' Overlander
Springfield , Missouri
What Converter?
I have a 1971 Overlander that I am about to take on my maiden voyage (if we have any sort of warm day). Since I have some cold days to do some work, I KNOW it's time to replace the original Univolt. The old unit is not charging my battery and it hums too loud right under my pillow! Soooo, what unit do you folks recommend? And, is it very hard to replace given I am a novice with electronics (pretty handy, though)? If you think I can do it, does it come with explicit instructions or can I find them somewhere on a thread in the forums?
Thanks for your help!!!
Ag'71 is offline   Reply With Quote
Old 12-01-2010, 05:21 PM   #8
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I bought an Iota 45 amp from Randy at BestConverters.com (on his recommendation as to my needs and his experience). So far, I have been very happy with the unit. Might want to give Randy a call, he is very helpful.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 12-01-2010, 08:14 PM   #9
1986 25' Sovereign
Plant City , Florida
I just purchased a 60amp Xantrex true charge2 with remote panel and temp sensor. I have not recieved this yet but from what I hear they are very good. This unit is some what more than most units but I already have several Xantrx products with great success.
I would suggest calling randy @ bestconverter.com however you will pay for his expert info as his prices seem to be slightly more than others.
Just my .02
ck21084 is offline   Reply With Quote
Old 12-01-2010, 09:05 PM   #10
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
it's Value Added -
Just my .02
I would agree on both counts, however,
based on my own firsthand experience, Randy's expertise & knowledge is worth the increment....
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 12-02-2010, 06:28 AM   #11
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I think he'll price match, call Randy at BestConverters.com
In this economy who would turn biz away
'77 Sovereign Intl 31' CB
Old 01-31-2011, 01:10 AM   #12
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Thanks for the reference to Randy- I'm hoping there is a way to easily swap out the old Univolt- mine works but I'd like to add a solar panel to help keep the battery topped up, and wondering what can of worms I'm opening
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Power Converter & Power Supply Land Shark Batteries, Univolts, Converters & Inverters 8 05-11-2010 10:51 AM
new power supply now tripping GFI housebg Batteries, Univolts, Converters & Inverters 32 04-16-2009 02:15 PM
UPS back-up power supply in an AS? richinny Batteries, Univolts, Converters & Inverters 8 09-30-2008 02:17 PM
Power supply ? starflyte1 Batteries, Univolts, Converters & Inverters 4 03-19-2007 09:29 AM
Power Jack electric supply GREGLC53 Electrical - Systems, Generators, Batteries & Solar 10 12-31-2006 04:35 PM
