07-01-2011, 08:07 PM
#21
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I just replaced my Walmart deep cells with Interstates.
07-01-2011, 09:06 PM
#22
1986 25' Sovereign
Southern Middle
, Tennessee
While I have the Intellipower, my trailer is running off 265 watts of AMSolar panels and a a group 27 Trojan 12 volt battery for the last 5 years. Next year I will probably go with dual Trojans and an external battery box behind the propane tanks between the frame rails. The Trojans are good batteries.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
07-01-2011, 09:08 PM
#23
2000 25' Safari
Davidson County
, NC Highlands County, FL
Bang for your $
Originally Posted by TG Twinkie
I agree with Mexray. A deep cycle group 27 battery is what I use. The last one cost me $65.00 at Wal Mart. If I get 2 years out of it, I figure I'm ahead of the game.
I agree with TG Twinkie and Mexray. I have always used lead acid deep cycle, since they serve my needs. I acknowledge the AGM's and Gel batteries are a better product, but they cost too much.
It simple math - cost per year= cost of battery/years of service.
I have used Interstate, DEKA, NAPA, Delco, and Walmart.
Lead acid will always win in cost comparisons, but not in performance. If I get 3 to 4 years, at around $20 per year per battery, IMHO, that's bang for your buck.
And lead acid batteries are recycled, so they are green too.
07-02-2011, 04:20 AM
#24
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
[QUOTE= AGM's and Gel batteries are a better product,[/QUOTE]
no mas on the gel's fo RV's.
"You don't know where you've been until you leave, enjoy life" RLC
07-03-2011, 09:17 AM
#25
2000 25' Safari
Davidson County
a battery with gel (thickened) electrolite. it is not as likely to spill.
they are used in marine and rv applications
07-03-2011, 11:20 AM
#26
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Talk about hijacking a thread!!!! SHEEESH!!
Anyway, gels are VERY tempermental in their charge voltages and the slightest bit of over voltage will cause the gel to strip from the plates...leaving a scar that doesn't heal and a marked decrease in capacity.
Go with a quality AGM like Lifeline. Built to mil spec and bomb-proof (and bomber proof as well, since they are found in all of our military aircraft)
Lew Farber -RVIA Certified Master Tech.... MASTER TECH RV SYSTEMS, INC.....AM SOLAR INSTALLATIONS ....
MAGNUM INVERTERS....LIFELINE BATTERIES
NO MORE AIRSTREAM.... NO MORE MEMBERSHIPS....BUT I'M STILL AROUND!
I'll stick with what others say......especially "the Lewster"
07-03-2011, 12:39 PM
#27
Master of Universe
2008 25' Safari FB SE
Grand Junction
It really does depend on what you do and what you can afford. Our trailer, like many, came with cheap series 24 wet batteries. Better batteries are series 27 and up; they will be larger. Ours started showing age last year when they weren't holding a charge very well. This year it was worse.
The battery box does not easily fit larger batteries. Since different companies make their batteries in slightly different dimensions, different modifications to the battery box will probably be necessary. You can golf cart batteries (use 2 6 volt batteries), but they are higher and the box lid has to be removed (just drill out 3 rivets, takes a few minutes) and a filler has to be added for the added height.
What you do also depends on the converter. Cheaper ones have a one stage charger and will cook the batteries if you keep it plugged in all the time—some of that is partially solved by checking regularly and adding water. Every month in winter, maybe sooner in summer. If you always have hookups, check batteries all the time, and buy cheap batteries, that can work. You do need batteries when you travel so you have some electricity when not plugged in.
But, the OP has an old converter and it would be best replaced. Lewster is an expert on things electrical and recommends Iota converters—they have a multistage charger and this will extend battery life. He told me it is the most trouble free converter he knows of. I installed one last week. The electronics in new converters are very sophisticated and charge batteries very carefully, extending battery life.
AGM's cost a lot more and are supposed to last a lot longer. If you boondock sometimes and have solar they help because they are better batteries and do better with solar charge than other batteries says Lew. Since he has a master's degree in electrical engineering and has been doing RV tech for a long time, I take his word for it. Having watched him work, I know he is thorough. With the OEM batteries, even after charging all day long via a 96 watt solar panel, at night when the furnace running, voltage would drop below 50%, not good for batteries. On cloudy days, or where the solar didn't get much gain because of short days, trees or canyon walls, it was worse. Better batteries with more capacity should solve that and that extends life.
We don't boondock a lot, but when we do we need electricity and prefer not to use the generator. If you boondock lots, superior batteries, an efficient converter and solar are the best way to go. We have upgraded our solar to 200 watts and for that 2 Lifelines, series 27, are good enough. Some people go to 300-800 watts and would need bigger batteries and to replace the battery wiring in the trailer. Lew and I discussed going with lower gauge (bigger) wires, but with 200 w. we didn't really need it and fishing them through would be very difficult in our floor plan and not cost effective. If you do the full monte (no photos if you are dancing it), you can go with more than 2 batteries—with AGM's you can install some of them inside because it is very unusual for them to offgas. If you seriously overcharge them, they can, but a good converter will prevent that. For a really big installation, people will also install an inverter to get 120 v. for major appliances, but that will run multi-thousands and is very cool. But not so cool the A/C will run a long time.
To install series 27 I had to cut back a lip 3/16" in the battery box and they fit, just barely. Lew estimated the Lifelines will last 7 years. By that age (mine) my nurse will have to lift the batteries out since they will be slippery from my drooling. Our converter and breakers/fuses are behind a face plate which is attached to the OEM converter—to install a new converter the front of the OEM converter has to be cut off and the new converter can be screwed down to the floor.
If you are restoring a trailer, that would be a good time to upgrade wiring since you may later decide to go solar. We always seem to need more electricity, so planning ahead it a good idea. Newer trailers have many drains on the batteries—furnace, fridge and water heater all use electric ignition, propane warning system is hard wired, subwoofer is always on (install switch to turn it off), for ex. Many came with lamps that use a lot—old fashioned light bulbs. LED's may be standard now, and we installed LED's a couple of years ago. The difference in power drain is remarkable.
There are many threads on all these questions and some searching will educate, confuse and overwhelm, but it is the process of evaluating what is best for you.
Gene
08-04-2011, 03:37 PM
#28
2010 25' FB Flying Cloud
Laramie
, Wyoming
I'm installing dual batteries end to end behind the propane tanks on the Bambi. Can anyone recommend a battery box for this setup?
Antique Pedaler
2021 Caravel 20 FB
08-04-2011, 03:50 PM
#29
Master of Universe
Grand Junction
You may have to build one. If you get AGM's, you can put one or both inside the trailer.
Gene
08-04-2011, 03:52 PM
#30
Aluminum Falcon Mechanic
1972 31' Sovereign
Wesley chapel
There is a guy on eBay that makes custom aluminum a-frame boxes
08-04-2011, 04:23 PM
#31
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
These are available, but I would worry about having expensive batt's in an un-locked box.
http://www.buyautotruckaccessories.c...m-battery-box/
Custom may be the only good option.
