Old 03-19-2008, 10:52 AM   #1
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
What is the best converter?
I have installed two AGM batteries, and intend to repalce the univolt. I would like to hear your opinions on the best multi-stage charger/conveter.
Thanks in advance for the input.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 03-19-2008, 12:42 PM   #2
hshovic's Avatar
2007 25' Safari FB SE
Bozeman , Montana
Images: 20
I replaced my batteries with AGM's, and got a 3 stage converter (Ultra III) from Randy at BestRCConverters.com to replace my 1 stage parallax in a Safari. The converter works well. I had to send one back because of the fan noise, but the second one works quietly. The fit was slightly off, but I just used two of the four screws, and it fit fine then.
Wiring was not difficult, just took some time. Make sure and disconnect power and battery first!
Hank
WBCCI 1489 AIR 20708
2015 Chevy 3/4 ton 4 x 4 gas; 2007 Safari FB SE
"Its better to light just one candle than to curse the darkness,
Unless you're blinded by the light..."
hshovic is offline   Reply With Quote
Old 03-19-2008, 01:42 PM   #3
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi
Try Intell Power converter. I am very happy with ours.
Regards Russell in Tucson Az.
RUSSELL is offline   Reply With Quote
Where's the converter? gparker Batteries, Univolts, Converters & Inverters 4 08-24-2007 03:30 AM
tv converter.. safari05-25 Audio, Video & TV 0 11-27-2006 07:10 PM
Need Some Help - converter jjohnjr Interior Restoration Forum 0 08-23-2006 06:21 PM
Voltage Converter or not? SoccerFolks Batteries, Univolts, Converters & Inverters 5 10-09-2004 11:50 AM
Why use a converter? PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 11-27-2002 06:52 AM
