Old 04-09-2016, 04:32 AM   #15
MOS
2016 28' Flying Cloud
Queensbury , New York
NoResults,
How did you make out at the dealer?
Mike
MOS is offline   Reply With Quote
Old 04-09-2016, 05:43 PM   #16
2016 23' International
Salem , Oregon
They told me that the batteries are fine just need to charge them for three days to get them fully charged.
I had not let them charge for more than a day thinking, after reading these forums that it was not good to leave them charging.
They suggested that I buy a replacement charger for $500.00
I am looking at the replacement for the Paralax 8355 but not sure I think it is the Progressive Dynamics 4655 but have not received a reply to my email to Best Converters.
Can any one suggest another source that could confirm if this is the proper replacement.
I am sure I can do it myself and save $300.00
Dave
NoResults is offline   Reply With Quote
Old 04-09-2016, 05:53 PM   #17
lewster's Avatar
Naples, FL , Hood River, OR
Use the Prog. Dyn. PD 4655 if you have 30 amp service in the trailer. Use the PD 9260 which is a deck mount unit if you have 50 amp service.
These are my go to units when upgrading the Airstream's charging systems when I don't use a Magnum inverter/charger.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Lew Farber...ABYC Certified Master Marine Electrician...RVIA Certified Master Tech ...AM Solar Authorized Installation Center...AIRSTREAM Solar & Electrical Specialist
lewster is online now   Reply With Quote
Old 04-09-2016, 06:28 PM   #18
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Lewster is right on. About 12.2 volts is 50% charge in an AGM or flooded 12 volt DC battery. To get to the estimated state of charge the batteries need to be resting with no loads in or out. They should rest for an hour or two to settle near their true state of charge. That is why a SOC meter is so important to battery management. They give state of charge based on amps used and amps restored. It is very seldom that you will be reading your battery voltage after completely resting them. A SOC meter is only as good as the parameters you set up for it.
Don and Lou----Don posting
'06 Safari 25 LS
'97 Chevy Suburban K2500 Diesel
TN, Greenest State in the Land of the Free
" America is not a place;it is a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 04-21-2016, 04:11 PM   #19
Salem , Oregon
Dealer says to keep me happy they will exchange the batteries. They also state that a drain to 12.2 from fully charged in 5 hours is normal? If they are correct should I just forget these batteries and bite the bullet for AGM batteries. I was not planning on adding solar at the present so the price and weight of the agm batteries need to be ruled out for the present.
How long should a fully charged battery stay charged from 12.6 when charged with no load other than the co2 detector.
PS: I did upgrade the converter to the 4655 with charge wizzard.
Dave
Old 04-21-2016, 04:34 PM   #20
lewster's Avatar
Their answer was way too vague. Battery draw is wholly dependent on the load being placed on them.
The battery industry used what is called the '20 hour rate' for battery capacity.
If you gave a pair of Gp. 24 Interstates, their 20 hour rate is 80 amp/ hours. Since you have 2 in parallel, you have a total of 160 amp/hours of which 50% is practical for usage.
5 hours of run time on fully charged batteries equates to a continual 16 amp load (80/5=16). That is a whole lot of battery draw continuously.
Even your energy hog furnace will not draw that amount.
Since you now have a quality converter, use them and see how it goes. Just be sure to FULLY recharge them ASAP after a deep draw and watch your water level.
Lew Farber
Lifeline AGM Batteries**Magnum Inverters***Victron Energy Components
541-490-6357
Old 04-24-2016, 11:31 AM   #21
Salem , Oregon
Even with the PD 4655 the charger never gets to storage mode just stays at normal mode of charging at 13.6 volts. I have not got the new batteries yet as I hate to make another 100 trip to the dealer so will have till wait till mid may for an appointment for other things.
Should I let the batteries set for a while then put it boost mode?
Thanks Dave
Old 06-15-2016, 06:26 PM   #22
Hans627's Avatar
2009 25' FB International
Hanover , Pennsylvania
I've been reading some of the posts relative to batteries to try to get a better understanding. I have older analog voltmeter which I'm beginning to believe is not accurate enough to read tenths (unless I'm not using it correctly). I read in your post about a SOC meter. I have no idea what that is. Could you (or someone) provide a description and some information?
Thanks!
Old 06-15-2016, 07:02 PM   #23
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
[ATTACH]264546[/ATTACH
Sent from my iPhone using Airstream Forums silver bp
Name:	ImageUploadedByAirstream Forums1466038907.302302.jpg
silverbp is offline   Reply With Quote
Old 06-15-2016, 07:02 PM   #24
silverbp's Avatar
LaMarque , Texas
This might help.
Old 06-15-2016, 07:39 PM   #25
2006 25' Safari
For long life try to keep your batteries at least at 50% state of charge.
'06 Safari 25 LS
Old 06-15-2016, 08:02 PM   #26
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Its not really the depth of discharge.... its how long you leave it there and not bring it back to full!
Old 06-16-2016, 04:53 AM   #27
Hans627's Avatar
Thanks. And just what is a SOC meter?
Old 06-16-2016, 05:32 AM   #28
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
SOC = state of charge
12v
Low voltage doesn't work, battery not charging bradleyoder Batteries, Univolts, Converters & Inverters 24 05-16-2015 11:00 AM
Acceptable voltage drop on 12V? ESCAPE POD Batteries, Univolts, Converters & Inverters 16 02-24-2011 09:41 AM
how low is too low AC voltage? WineStream Electrical - Systems, Generators, Batteries & Solar 59 12-18-2009 02:56 PM
Low voltage... converter or battery problem? patrickdylan Batteries, Univolts, Converters & Inverters 5 08-22-2009 09:24 PM
Low-Voltage Battery Alarm rseagle Electrical - Systems, Generators, Batteries & Solar 14 04-19-2006 08:19 PM
