Old 06-29-2013, 02:27 PM   #1
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
What is an inverter? Do I want?
This is as I understand an option that allows you to convert 12v (from charged batteries)to usable electricity for say an iPod - phones - etc when not plugged into shore power
I may be confused - but if you plan on the generator route - then is the inverter needed for boondocking?
PharmGeek is offline   Reply With Quote
Old 06-29-2013, 02:33 PM   #2
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Also - quick question with this - if you have 2 AC units on a new 30' model - is there much a benefit to awnings all the way around?
Old 06-29-2013, 02:38 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
An inverter converts 12v power to 110v power...we have one our 2006 19' Bambi ...it's a 600w ...and we like it a lot...we can use it to charge laptops and phone and run the TV...and small appliances (nothing that requires more that 600 watts) without having to crank up our generator. It's quite handy. It delivers power to a special set of outlets (not as many in number as the regular 110 outlets)...
TB & Greg and Abbey Schnauzer
#3954
Old 06-29-2013, 02:39 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
An inverter will let you get 110 without running your generator. There are 2 types true sine wave $$$$$ and modified sine wave $. Some electronics don't like the cheaper modified sine wave inverters. You also use about 15% more power converting DC 12 to 110AC
The same applies to generators. True sine wave generators are more expensive, and quieter, than the noisy construction type.
Old 06-29-2013, 02:40 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
As to awnings all the way around... your ACs will work better if you have awnings all the way around...but they can always be added post-purchase if you are wondering about it. That's what we did. Of course in our climate, it's doubly good.
#3954
Old 06-29-2013, 02:44 PM   #6
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
But with generator - I would need to be running the generator to power the laptop for example? With inserted I can charge batteries with genie or solar and if cool at night can use battery power to tinker on computer and watch tv....
I guess I can see that as a nice mod to have...
Otherwise if off shore power I would need to have generator running to power the tv correct?
Old 06-29-2013, 02:45 PM   #7
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Also - how hard would it be to install an inverter later? Is it a plug and chug type of deal on a 2013 bunkhouse or does it require extensive new wiring etc?
Old 06-29-2013, 02:49 PM   #8
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
If the awnings are within your budget you will appreciate them on a hot sunny day. They will help keep the temps down in the AS and the Air Cond. will do it's job more efficiently. I think the main awning is a must for obvious reasons. The rear and other side are optional but will be appreciated.
In my opinion the inverter is optional. It will allow you to convert stored battery power to household 120v for use with some small appliances when boon docking. We don't have one and don't really see a need. If you boondock using a generator ( and we do ) it may give you some flexibility. I'm sure you will get some other opinions here and hopefully they will help guide you to making your decision.
Good Luck, see ya on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is online now   Reply With Quote
Old 06-29-2013, 02:58 PM   #9
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Well - I'm to the point in deciding a 2013 vs 2014 model - price on both very good - a bit more for 2014
Starting to think I should get the 2014 that has all that I want
Old 06-29-2013, 03:06 PM   #10
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I would definitely opt for the 600W inverter. Without it, unless you have 100V you will NOT have TV, nor will you be able to recharge your iPhone, computer, etc (unless you get a 12V adapter). The 600W inverter is a true sine wave inverter and works well with your electronics. You can definitely install it later, but if you order it with your trailer you will have special 110V outlets in each section of your trailer that are MARKED as inverter circuits....if you add this later (unless you want to rewire your entire trailer), you will probably have only one place to plug in and get 110V without being either plugged into a campground or using your generator. Also, you definitely want the awning package. They do a great job on the rear window and the SS.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-29-2013, 03:09 PM   #11
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Burger king time
Old 06-29-2013, 03:11 PM   #12
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
The inverter is actually 1000W for 2014
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 06-29-2013, 03:12 PM   #13
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
This is correct
Old 06-29-2013, 03:38 PM   #14
Lumatic's Avatar
1993 34' Excella
Images: 16
You can get an small inexpensive inverter that plugs into a 12v outlet.Voila! no installation. Or a bigger inverter hard wired and permanently installed.
Heart Interface inverter manual needed malconium Batteries, Univolts, Converters & Inverters 2 05-07-2014 11:57 AM
Inverter guidance ostream Batteries, Univolts, Converters & Inverters 2 04-21-2011 08:20 PM
Need advice on inverter replacement for Paralax Nightwatch Electrical - Systems, Generators, Batteries & Solar 1 02-13-2011 01:04 PM
