06-29-2013, 05:25 PM
#21
2013 30' Classic
Greenwood
, Mississippi
Do you plan to boondock or dry camp? All of my camping has been in campgrounds/parks with electricity.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
06-29-2013, 05:30 PM
#22
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We are considering a 2,000 watt inverter (requires four batteries versus the standard two for a 1,000 watt inverter) when we do the 300 or 400 watt solar system. This will definetely be a non-dealer installed option.
You will need to get a device called kill-a-watt (most hardware stores carry a version of this) to determine your power use by each appliance. There is no free lunch. You can uase only so many watt hours of power before recharging the trailer batteries.
The Honda generators generate sine wave power. Some of the less expensive brands to not generate sine wave power.
06-29-2013, 05:34 PM
#23
2014 31' Classic
Apache Junction
I look forward to hearing the date of your build slot. Unless the dealer swaps your unit into an existing order slot, the unit might be scheduled later this year or the first of next year.
When you special order a trailer, you are allowed to photo the build process in person at Jackson Center. It appears they have reduced the build time to five work days from seven work days in June of 2012.
06-29-2013, 05:53 PM
#24
Naples
Originally Posted by switz
The new 2014 models will support a 1,000 watt inverter, which is preferrable to the 600 watt inverter that is no longer offered. I have been told the Airstream inverter can not be retrofitted in the field. Thus it must be specified at build time. It is a $725 option in the Classic models.
Switz,
You have been mis-informed! It CAN be done and IS done EVERY DAY! I have retro-fitted 8 inverters into Airstreams alone (many more into SOBs) when adding a large, comprehensive solar battery charging system. The smallest was a 1000 watt pure sine wave model and the largest a 2800 watt sine wave model. An inverter can be installed into ANY RV at ANY TIME.
The best part of these inverter installations (Magnum Energy products) is that you get a superior charging section for your batteries (generally upgraded to Lifeline AGMs on these installations) that is fully adjustable for type of battery, size of battery bank and most important, full temperature compensation for proper charging in all conditions. AND...........all Magnum products are fully field serviceable if anything happens to fail.
lewster
06-29-2013, 06:11 PM
#25
2012 25' FB International
Trent Woods
, North Carolina
What some people do not realize is the potential large drain on the batteries with an inverter. In round numbers, take the AC amps of the load and multiply by 10 to get the DC amps, then multiply by the hours of use to figure the drain on your batteries. In short, you are not going to power a toaster. An LCD TV is fine as are the electronics people are mentioning. You only have about 100 amp-hours to 50% before you must recharge the batteries. So inverters can be handy,, but you need to watch your batteries.
Larry
06-29-2013, 06:46 PM
#26
1984 34' International
Toronto
, Ontario
Inverters can be really useful, especially if you've got a serious bank of solar panels on the roof.
I know people who fulltime and power their iMacs (these guys are programmers/web designers) almost entirely with their 600W solar array.
06-29-2013, 08:10 PM
#27
Naples
Of course you can run a toaster.....you can run an electric coffee pot and a microwave too! Yes, you have to watch your battery condition and depth of discharge, but it's done every day....... even with a 200 amp/hour battery bank.
EXAMPLE..............
You toaster draws about 800 watts (mine does). At 120VDC, this gives you a 7 amp draw (actually 6.6, but we'll use round numbers). A 7 amp AC draw is equivalent to a 70 amp DC draw. Add 15% for inverter inefficiencies (10 amps DC) and you have an 80 amp draw from your batteries.
This seems like a huge amount......BUT REMEMBER......... it only takes a couple of minutes to toast a piece of bread. A generous estimate is 1/20 of an hour....or 2.5 minutes. You divide 80 divided by 20 which is a real battery drain of 4 amp hours.
A 200 amp/hour battery bank has 50 % useable amperage, or 100 amp/hours. The toaster's draw is 4% of your useable battery capacity........easily replenished with a quality solar charging system in short order or left alone for a short generator run at sometime later in the day.
Class dismissed!
lewster
06-29-2013, 08:37 PM
#28
2014 30' FB FC Bunk
Hoover
, Alabama
Not sure it will help - I also have a blue top optima I use in my boat - not sure that will extend things...that battery runs my trolling motor quite a while.
Yes we wi plan to boondock - not tons early but we will - we know some places and folks with land up in north east Alabama. Also weekend trips off the grid with my brothers will occur - etc.
It will not be a staple - but it will happen.
Can a charge on the batteries keep the trailer warm overnight in say the 30's and 40's overnight?
We plan on getting a generator(s) - have been dying for one to run the freezer and fridge at home in the case of power outages - to use to run the AC - charge batteries - etc when off shore power but will forgo this till next year (and hope we do not get a bad power outage this year).
The main thing I would want to run on batteries for a bit is tv, charge phones, computer.
It's all on order as such - im sure the 1000w inverter will be handy.
I do understand would need genie for air conditioner to run (that will be a whole different subject to consider next year).
Hmm I wonder if my truck can charge the batteries....my truck will arrive in a week.
Thanks for all the advice folks - im sure I learn a lot by experience - I'm not worried
06-29-2013, 08:39 PM
#29
2014 30' FB FC Bunk
Hoover
, Alabama
Solar panels will be a consideration for later travels - but I'm doubting I will go that route any time soon. Love the idea though - will consider much later - money tree is too lacking.
06-29-2013, 09:22 PM
#30
2013 27' FB International
El Dorado Hills
Class dismissed!
I've heard that deep cycle batteries don't like rapid discharge. Wouldn't a toaster demand a lot of current in a short timeframe? Spread across a large bank of batteries (say 6 to 10) might mitigate the draw.
06-29-2013, 09:32 PM
#31
2014 30' FB FC Bunk
Hoover
, Alabama
that optima takes repeated shots from my trolling motor...on and off...on and off...assuming no wind that day much, it can keep going nicely for a solid 5 hours (conservative) under frequent use...but more practically it goes 7-8 hours with usual moderate use....
I am not sure how that correlates with a toaster, a TV, etc?? Im electrically a dullard
06-29-2013, 09:33 PM
#32
2014 30' FB FC Bunk
Hoover
, Alabama
oh, and those numbers include running my sonar unit (a 9 inch screen) during the whole time period...
06-29-2013, 09:41 PM
#33
2006 25' Safari
St. Augustine
Hey Pharm Geek
Lots of info here. Here is my experience on this. I purchased a used AS a year and a half ago. I added an inverter to it last December. Basically it added the ability to use electrical devices even when the trailer was not "plugged in" adding more than interior lights to the experience. In January I ended up boondocking in a parking lot and was fine using the inverter for the TV, the coffee maker and blue ray player. My truck charges the house battery while traveling. I DID go the generator route though for the need of AC. The inverter uses power like crazy. I also had to pay more for a SINEWave Inverter since my tv would not work on the first one I purchased which was modulated. At any rate, even the best inverters have a conversion efficiency in the low 90th percentile. So, you are losing a chunk of power during the drain which means - time out what you want to do and cut it off ASAP- That or carry a bunch of batteries around. The generator option allows for full charge in a few hours 2-4 and also provides an option for AC use. Solar cannot do the latter and still requires a battery array. The inverter provides a quick use without generator hookup of your little stuff. My invertor shows "how much time at current draw rate" by indicating the draw, then showing the remaining voltage. I figured that I could watch tv with disc player for about 6-7 hours or make coffee for about 45 min on my house battery spec. before running down to the min remaining voltage. It never drains the battery all the way down. BTW, the eletrical wiring to the inverter was to me, massively heavy wiring as required by the manufacturer. I had to use the large wiring between my batteries too and add a trip fuse. What is important is the battery AH rating and RC and I found that these are not always better than say AGM batteries, which charge more times but cost a lot more too.
06-29-2013, 10:50 PM
#34
2006 19' Safari SE
Tucson
Seems to me you are going to be pretty well outfitted to start. We went some time before we got generators, but when we started doing more dry camping it was an obvious need. Then we only bought one Honda 2000 to start ... 18 mo later we got the 2nd. We really like the solar, which was factory-installed. WE went nearly 6 years on our original AGM batteries (2) and when we finally replaced them we were pretty astounded at the difference it made to have healthy batteries that could actually hold a charge well. (What a concept!) And the solar became far more efficient, as well with good batteries. Don't worry about solar at first if you don't want to. Your rig will no doubt be prewired for solar and it's probably better to have that added later because you can get a better system post-purchase ... you have lots of real estate up on top of a 30' for panels (unlike a 19"...it's pretty full with two vents, AC and a solar panel). You're gonna love your rig.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
06-30-2013, 04:30 PM
#35
2014 30' FB FC Bunk
Hoover
, Alabama
Thanks!!
It is pre wired and what I have gleaned from this site - I will wait till later and buy a different system...the price tag already is growing too much - gotta cut it off somewhere or no money to ACTUALLY camp
06-30-2013, 05:46 PM
#36
Trent Woods
, North Carolina
Lewster, this is probably not the thread to argue this point but of course the numbers support a toaster, even up to 300 amps out of the batteries. That is not the point...the batteries do not like it and you will end up with shorter battery life with high amperage discharges. Deep cycle batteries are designed for many cycles but not so much for high bursts, less so than starting batteries. Do whatever you want but AGM's are expensive enough that I do whatever I can to prolong their life. That means low discharge rates, even with many cycles, and long slow charging. I have very little control over the charging rate, but I have a lot of control over the discharge rates and toasters are forbidden on my inverter.
Larry
07-02-2013, 05:26 AM
#37
1995 30' Excella
Bowie
, Maryland
We have a 1500 watt inverter in ours (installed by the original owner). It's large enough to power the microwave for some reason. But we rarely use it.
You're really only going to use it if you go camping without shore power, and then only if you don't have 12 volt chargers - we have 12 volt chargers for our phones, iPads, etc. The times we've been camping/lifeboating (power out at home) without electricity, I never even turned on the inverter.
My suggestion: Wait until you see what kind of camping you do, then decide. If you find yourself constantly out in the backwoods wishing you had 120 volt power, then get an inverter. Otherwise, don't bother. If you're just powering small devices you can buy cheap ones that plug into 12 volt power outlets (I assume newer Airstreams still have those - ours has a lot less than ones from the 70s do, I know) to give you 120 volt power for that specific device. But you're much better off to get 12 volt car chargers to recharge phones and the like than you are to run an inverter for those.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
07-02-2013, 05:48 AM
#38
Toronto
, Ontario
I do think the word "camp" is important.
For me, the Airstream was always one step short of hauling a house. I'm sure that for fulltimers the needs are very different, but when we're out camping, we don't really need much power.
For example, one of the first things we got rid off was the microwave. Don't need one, don't want one, in the trailer or at home.
