Old 04-03-2012, 05:19 PM   #1
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
What is a Univolt? :-)
I know WHAT a univolt is, I know what they do, and i have a very good idea of HOW they do it. Can someone possibly tell me how a Univolt is different than say, and Astron RS20, 20amp power supply? They seem to me to function exactly the same and serve the same purpose...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
aircooled4 is offline   Reply With Quote
Old 04-03-2012, 05:41 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Ok. Here's an educated guess. The Univolt is more like a battery charger than a power supply. Especially if the power supply is a regulated type. The power supply puts out a constant and fixed voltage up to it's rated capacity. Whereas a battery charger (at least a good one) will vary the voltage depending on the state of the battery being charged.
In my opinion the Univolt is a crude battery charger and is noted for cooking batteries.
The modern converters used in RV's are intelligent to a point. As the converter sees the state of the battery change it adjusts itself accordingly. Whereas a power supply does not have that capability. Typically regulated power supplies are used where a fixed voltage level is required, in electronic circuits for example.
A power supply would not be a good choice for charging a battery.
Old 04-03-2012, 06:06 PM   #3
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Thanks that kind of explains it...We're restoring a 67 Safari...Today i removed the univolt and was wondering how it was different than a power supply and different than a battery charger...
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
Old 04-03-2012, 06:09 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
After removing the one in my Trade Wind, I would say that a Univolt is more suited to marine use.
It would make a better boat anchor.
Vaughan
Old 04-03-2012, 06:20 PM   #5
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
I believe much of the weight is copper.
You may want to recycle.
I didn't think of this until I used my old ones for boat anchors. Oops.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 04-09-2012, 10:03 PM   #6
New Borockton , Alabama
Images: 21
That couldn't be more true.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 04-09-2012, 10:49 PM   #7
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
I believe a Univolt is actually a ferroresonant transformer.
They are old-school technology, but are generally quite robust and resistant to variations in input voltage, power spikes, etc.
They make a fair amount of noise humming; I'm going to use my old one as a 30A battery charger in the garage.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
What did a Classic Motorhome Cost New? Keyair Classic Motorhomes 42 08-12-2012 06:39 PM
Window gone - what happened? jgerardi Windows, Doors, Locks & Vents 17 04-05-2012 06:55 AM
HELP! found '68 Land yacht is this good price? womanofsteel Trailer Values 7 04-03-2012 04:38 PM
What is it - pressure reducer? 68ambassador Fresh Water Systems 5 04-03-2012 07:42 AM
Pump is pumping, but! AWCHIEF Fresh Water Systems 10 04-02-2012 05:02 AM
