Old 03-02-2006, 05:36 PM   #1
Skutman
skutman's Avatar
2006 16' International CCD
Jamestown , Tennessee
What is a UNIVOLT?
I have just brought home my new Quicksilver. Been trying out all the systems. My speakers have a hum when I have either DVD or CD playing. In trying to find problem, I see references to "Univolt." Is this the battery charger and how could it be causing the problem?
skutman is offline   Reply With Quote
Old 03-02-2006, 05:58 PM   #2
1973 29' Ambassador
Troutville , Virginia
Univolt is the converter that uses 110 volts to charge battery as well as keep up with your 12/110 volt outlets.- the newer univolt should have a 'filtered' outlit to take care of this problem. Jim J
Jim Johnson is offline   Reply With Quote
Old 03-02-2006, 06:13 PM   #3
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
You can get an inline power filter for the radio like at radio shack. You would have to cut the power line to the radio and wire the filter inline.
It will filter out the noise. Better filters than radio shack would offer could be purchased at nice car stereo shops.
They probably cost about $10 - $20.
-Tim
theVAP - Airstream Podcast
Old 03-02-2006, 09:26 PM   #4
cammur's Avatar
Roseville , California
Again, I'd put it on the fix-it list for my next warranty visit to the dealer, before I'd put much effort into it.
Cam
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 03-02-2006, 09:42 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
This is an easy diagnostic procedure.
Unplug the trailer and run it on battery only. If it still hums, then your Stereo is the culprit. If it does not hum any longer, then it is likely the charger/converter.
Batteries deliver the ultimate DC power. Hum is usually caused by A/C power. A bad filter inside the converter/charger can cause A/C content in the D/C charging current, and manifest itself in an audio system hum.
Uwe
www.area63productions.com
Old 03-02-2006, 10:11 PM   #6
Do UWE's diagnostic procedure Then
Look on the panel of your converter for the lug's marked filter mine were empty . Next find your radio power circuit and move to the filtered lug. Friend gave me his newer univolt after he upgraded to Intel power for the same hum buzz.
OakHill is offline   Reply With Quote
Old 03-04-2006, 08:55 PM   #7
Skutman
skutman's Avatar
The hum is present on either AC or DC. I think I'll let the dealer handle it. Thanks for the info.
Old 03-04-2006, 09:46 PM   #8
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
My guess would be that the player has issues.
Uwe
Old 05-09-2006, 09:33 AM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
same problem
I have the same symptoms (but I have just put in a new radio), Uwe, are you recomending against the radio shack filter?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Bad Univolt? pebblepoint Batteries, Univolts, Converters & Inverters 1 07-14-2002 10:08 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
Univolt Operation melprice Electrical - Systems, Generators, Batteries & Solar 11 06-17-2002 04:13 PM
