Old 04-10-2010, 12:04 PM   #1
Birmingham , Alabama
what do the M and S represent on the low voltage schematic?
The low voltage schematic has circled S and M symbols. What do these represent? thanks in advanced.
scssmith is offline   Reply With Quote
Old 04-10-2010, 12:32 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
A Circle M is a motor. Not sure about the S. A Circle backwards S is AC Voltage.
Richard
Old 04-10-2010, 01:34 PM   #3
2005 19' Safari
GLENDALE , AZ
Can you scan and post a portion of the schematic?
Old 04-10-2010, 04:34 PM   #4
RBolton's Avatar
Belington , West Virginia
A/C voltage source symbol can look like this.
It's not a letter "S" but could be mistaken for one.
RBolton is offline   Reply With Quote
Old 04-10-2010, 04:49 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Seems like our manual includes an "S" symbol as well in the 12v circuit. It means "switch" -- or at least it corresponds in our rig to every point along the circuit that has a switch.
Lynn
WBCCI 21043
Old 04-10-2010, 06:39 PM   #6
I have attached a file. thanks for the info
Old 04-10-2010, 07:41 PM   #7
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Looks like a symbol to indicate a switch.
Garry
Old 04-14-2010, 01:33 PM   #8
2005 19' Safari
GLENDALE , AZ
I agree that the "S" looks like it indicates a switch and the "M" probably represents the furnace blower motor. However, the draftsman that drew this schematic didn't use standard electronic symbols.
Old 04-14-2010, 02:15 PM   #9
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
It is a switch and the M is a motor. A sideways "S" without a circle is a fuse.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 04-15-2010, 07:34 AM   #10
thanks so much for the help!
Old 04-15-2010, 08:43 AM   #11
HowieE's Avatar
Princeton , New Jersey
Images: 12
I have seen some intentionally confusing schematics, York AC units, in my day but is a close second.
Yes I agree the S, there are 2 leading to the furnace one for the thermostat and one as an on/off switch, is a switch and the M is the fan motor.
The problem is he did not indicate ground on the 12 system and has the 120 volt side drawn a a single line.
2004 Excursion 4x4
Simple question about low voltage dis panel schematic? Mrcrowley Batteries, Univolts, Converters & Inverters 10 08-18-2008 07:25 PM
Low voltage distribution panel...Help k9s2go Electrical - Systems, Generators, Batteries & Solar 4 12-29-2006 01:54 PM
Low-Voltage Battery Alarm rseagle Electrical - Systems, Generators, Batteries & Solar 14 04-19-2006 08:19 PM
Low voltage-A/C Dave-O Electrical - Systems, Generators, Batteries & Solar 10 04-24-2003 07:56 PM
Low Voltage Problem kellyw Electrical - Systems, Generators, Batteries & Solar 3 10-23-2002 06:35 PM
