Old 11-04-2011, 01:21 PM   #1
BREWHEAD's Avatar
1979 31' Excella 500
Charleston , West Virginia
What are the symptoms of a bad Univolt?
I have a 1979 Excella and I wanted to know what are the symptoms of a bad univolt? I think my univolt charger has kicked the dust which might of been spurred on by a power surge at a campground.
Any help would be great.
THANKS
BREWHEAD is offline   Reply With Quote
Old 11-04-2011, 01:49 PM   #2
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Based on what I have read on the forum, the first symptom of a bad UniVolt is that it is still installed in your Airstream.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 11-04-2011, 01:50 PM   #3
SteveH's Avatar
Common Sense , Texas
Jokeing aside, usually the first symtoms are no 12 volts after the battery runs down.
Regards,
Steve
Old 11-04-2011, 01:59 PM   #4
Or, it cooks the battery.
Old 11-04-2011, 02:30 PM   #5
Southwestern , Ohio
Measure your 12 V bus voltage with the trailer connected to ground power and disconnected from the tow vehicle. Should be somewhere in the neighborhood of 13 volts. If it's 12.5 or so the battery probably isn't charging; let some lights run for a while and see if it drops. Conversely, the old boat anchor convertors were notorious for overcharging the batteries; if you are seeing 14-15 volts that's too high. (Note: the current generation microprocessor controlled convertors give the batteries a shot of 14-15 volts now and then, but only briefly; a steady 14+ volts is too high.)
Our 1980 model has a DC voltmeter on the systems monitor panel--maybe yours does too?
Nuvite-F is offline   Reply With Quote
Old 11-04-2011, 02:36 PM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Hear, hear! That's exactly what a bad converter did to a battery in our rig. We kept on smelling something funny, almost like sewer gas, or so we thought. It was a boiling battery.
Lynn
WBCCI 21043
Old 11-04-2011, 03:13 PM   #7
SteveH's Avatar
Sometimes those "cooking the battery" events begin with a bad battery. I had one where one of the battery developed a shorted cell. The converter, an Intellipower I might add, kept pumping 13.8 volts to the batteries trying to bring up the bad one until the battery actually blew up.
After I replaced the batteries, all was well.
The original Univolts are not smart in any way, so they would be even worse.
Regards,
Steve
Old 11-04-2011, 03:15 PM   #8
1974 Argosy 20
Kooskia , Idaho
Yes, they are technologically obsolete by virtually all standards of electrical systems available today. Good in their time, but that is time is long gone.
Old 11-05-2011, 03:14 PM   #9
Skater's Avatar
1995 30' Excella
Bowie , Maryland
The original converter in the B190 was down to about 10 volts output when I replaced it. That was a pretty good sign, too.
The original converter in the trailer wasn't doing well, either - it wasn't able to keep up the voltage even when we had just a few lights on.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-05-2011, 04:56 PM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
In these parts we say the only good univolt is a dead univolt Pardner!
Old 11-12-2011, 10:55 AM   #11
darryl97420's Avatar
1974 Argosy 28
Coos Bay , Oregon
So that I may gain some insight from this thread...Disconnect the battery and check the output voltage to the battery leads? If its 13.0vdc its ok? What about when lights are turned on? I turned on every one I could find and the voltage dipped to 12.0vdc. Can I consider my Univolt to be in decent working condition?
I hope it isn't considered hijacking a thread when your looking for additional insight.
darryl97420 is offline   Reply With Quote
Old 11-12-2011, 01:20 PM   #12
The output voltage of a "Univolt" cannot be checked unless it's hook up to a battery or a large condenser (capacitor).
The output will measure very low, like 9 to 10 volts, unless that load is attached.
That would give a false indication of a bad Univolt.
Old 11-12-2011, 03:49 PM   #13
1974 Argosy 28
Coos Bay , Oregon
There is where my problem is. I tested the output without a load and it showed 13.0 vdc. Hum...
A new battery is going in later this week. Once installed I will retest the voltage.
Thank you Andy for your help.
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 11:16 AM
Univolt on a 1976 Caravanner wba1 Batteries, Univolts, Converters & Inverters 12 07-27-2011 07:13 PM
Univolt output voltage question GeocamperAS Batteries, Univolts, Converters & Inverters 8 07-13-2011 10:22 PM
