Old 08-22-2015, 05:18 PM   #1
Boxite's Avatar
2008 22' Sport
WFCO LED Fuse Fail Indicator
Here's a discovery I made (after some degree of frustration)...:
While installing new overhead light bulbs I accidentally shorted one out and all of them failed...indicating a blown fuse.
My WFCO converter has a column of Red LED indicators which are supposed to indicate a failed fuse. My presumption was that since each fuse has an LED beside it.... that must be the fuse indicated. WRONG!
No schematic existed to determine WHICH fuse serves which appliance circuit.
The LED at the top of the column was illuminated, yet the fuse beside it tested good. I spent the afternoon searching for burned wires and/or failed switches/connections/etc..
After much time spent on this I started checking other fuses in the panel and discovered that another fuse ...down the board... was blown. Replacing it restored service to the overhead lighting.
In other words, the illuminated LED was NOT adjacent to the faulty fuse. FYI.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
LED tank indicator panel for bathroom rippie Lights - Interior & Exterior 3 01-21-2014 04:32 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
Super Jack limiter fail chrisd37 Jacks, Stabilizers, Lifting and Leveling 11 04-13-2009 04:52 PM
Goodyear Marathons from 06 and 07 fail... norsea Tires 10 03-03-2009 10:13 AM
