Old 09-19-2016, 04:52 PM   #1
Tincampers's Avatar
Sneedville , Tennessee
WFCO inverter, fan but no juice
Turned on the inverter yesterday to charge up the laptop. I can hear the fans running but have no power at any of the outlets. Last week, it was on and working fine. I went outside for awhile and when I returned, the light on the remote switch was on, but no fans and no power.
Anything to check before I invert this into a boat anchor?
Tincampers is offline   Reply With Quote
Old 09-19-2016, 05:31 PM   #2
New Borockton , Alabama
Images: 21
It should be hardwired to your AC distribution panel or sub panel Make sure there in no 120 VAC there and the breaker not tripped before you dump it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 09-19-2016, 05:47 PM   #3
Tincampers's Avatar
Thanks Randy, checked the breaker and it didn't appear to be tripped. Reset it anyway. I have power out now.
If this does eventually fail, what's a good option for a replacement?
John
Old 09-19-2016, 06:01 PM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Since its a standalone inverter any 1000w will work. Just a matter of swapping cables and screwing it down. Samlex is a good brand. Or you could spend more and get an inverter/charger such as a Magnum 1012 1000w inverter/charge with the optional control panel will allow you to monitor the inverter, battery condition and set up customized battery parameters. Anything should be better than the WFCO inverter.
Kelvin
Old 09-19-2016, 06:20 PM   #5
Tincampers's Avatar
Kelvin
Thanks Kelvin, I will take a look at the Samlex...holding off on the Magnum until after I scope out my next bank robbery🤓🤓🤓!
Old 09-19-2016, 07:20 PM   #6
Images: 21
John
Samlex PST series is definitely our most popular stand alone but if you decide to go inverter/charger, their EVO 2200 watt is phenomenal. If your converter is still working or already upgraded, might want to save that $$ and get a stand alone but either will do the job. We serve a lot of Airstream dealerships and the PST 1500 and 2000 are the most popular but they do also make a 1000 if you only need it for entertainment 'stuff' and no heat devices.
888-828-1893
Bestconverter.com
Old 09-19-2016, 07:31 PM   #7
Tincampers's Avatar
Converter upgrade was the very first thing I did.
Do you have any information on wiring an inverter, say the 2000, with an automatic transfer switch on your website?
John
Old 09-19-2016, 08:04 PM   #8
Images: 21
John
Only the owners manuals John and some of them go into good detail, wire size, fuse, etc. There are tons of blogs and several here have done it too I know. Not difficult with basic skills.
888-828-1893
Bestconverter.com
Old 09-19-2016, 08:18 PM   #9
2015 30' Classic
Pleasanton , California
If you have a solar controller, it's possible that the WFCO inverter is in shut-down mode from possible over-voltage. I find that my WFCO inverter will shut down at times when my solar charger is running with very light loads on the battery. As soon I load the battery or wait till later afternoon I can then restart my inverter by turn it on and off at the remote.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 09-19-2016, 09:31 PM   #10
Tincampers's Avatar
You might have something there. I will test it again tomorrow when the charger is in a high voltage mode. Good catch!
Just looked at the specs and max dc input voltage is 15v.
Old 09-20-2016, 07:56 PM   #11
2005 28' Safari
Saint Joseph , Michigan
Hi Randy.. Still waiting for the part/enclosure .. Fred K
TruckerFritz is offline   Reply With Quote
WFCO WF5110H Inverter RivetingTrvl Airstream Classifieds 0 04-19-2016 04:03 PM
WFCO WF5110H Inverter - PRICE DROP RivetingTrvl Airstream Classifieds 0 06-21-2015 01:48 PM
WFCO WF5110H Inverter ghaynes755 Airstream Classifieds 0 05-25-2015 08:01 PM
Modification to reduce fan noise for the WFCO 1000 W Inverter alano 2011 - 2015 Classic (all lengths) 8 05-08-2015 02:26 PM
WFCO WF5110H Inverter ghaynes755 Airstream Classifieds 0 07-24-2014 09:28 PM
