Old 10-15-2014, 02:12 PM   #43
lewster's Avatar
Naples, FL , Hood River, OR
Sorry, but 'Myron' should change his name to 'Moron'!!! Deep cycle batteries are not measured by either CCA (cold cranking amps) or MCA (marine cranking amps). They are measured by the amp/hour capacity at a stated rate of discharge (usual standard here is the 20 hour rate).
Your battery manufacturer should have a table that tells you what the residual voltage should be after a known discharge using the 20 hour rate. Cranking amps is meaningless!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-15-2014, 02:21 PM   #44
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
They just can't keep good help these days
I told the dude about the boiler - I mean converter and he quickly said "you didn't add water to em did ya?!"
He went on about how many are meant to "vent" or some such...
PharmGeek is offline   Reply With Quote
Old 10-15-2014, 02:26 PM   #45
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Well - at least I think I can say the cells are not damaged.
I need to look up that table and I will run some load on the batteries and see how they act
I know 2 weekends ago they did the job no problems but that was a short weekend trip and I ran the generator a couple hours once as well
Old 10-16-2014, 06:09 AM   #46
1981 31' Excella II
New Market , Alabama
Make sure you only add distilled water not tap water. Actually running a CCA test might damage a deep cycle battery. Find a dummy load and run a test like I outlined above. It at least gives you a relative indicator of the capacity left in the battery. Here are some curves on batteries discharge. Try not to geek out. If you can find a large high power resistor you can use that but it will get hot.
https://images.search.yahoo.com/sear...scharge+curves
You need one of these. You can adjust the resistance from 25 ohms on down to get the load you want. You can measure current using ohms law and measuring the voltage drop across the resistor. I=V/R and also measure the voltage across the battery. P=IV to get the watts dissipated in the resistor. You need to keep track of the hours it takes to get the voltage down below 11V or whatever the manufacture considers dead.
http://www.ebay.com/itm/NEW-25-Ohm-1...item3ce96ba246
There are some USB data loggers on Ebay cheap but they have a 5V max input voltage. You could make a simple voltage divider circuit to drop the voltage to where the data logger can handle it. It all depends on how much time you want to spend to get your answer.
I would setup a Labview program to do this, if I were at work.
Perry
Old 10-16-2014, 01:05 PM   #47
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I think I still have a battery learning curve whew
Who's Thirsty???? Bluemoon64 Off Topic Forum 6 11-27-2013 06:42 AM
Cell Phone for full timer Gunnyusmc Full-Timing 79 02-16-2008 08:12 AM
Mucho Gusto - New Member South of the Border IzZihua Member Introductions 0 07-15-2006 12:55 AM
Cell phone provider question (T Mobile) yargseth Electrical - Systems, Generators, Batteries & Solar 20 04-10-2004 06:39 PM
Best cell service in Texas State Parks? JeffandSuzanne Our Community 14 02-20-2004 09:39 AM
