Old 09-29-2014, 10:31 PM   #29
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I spoke to randy at best converter
PharmGeek is offline   Reply With Quote
Old 09-29-2014, 11:42 PM   #30
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
If you currently have a Parallax 7355, you should be good replacing it with a Progressive Dynamics 4655. Here's a helpful web page from BestConverter that may help you decide what is likely to work for you: Magnetek/Parallax 6300/7300 Upgrade Kit
Old 09-29-2014, 11:48 PM   #31
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Main reason I upgraded to AGM's. No water problems to deal with. Also upgraded to a 3 stage charger.
TinCan
graysailor is offline   Reply With Quote
Old 10-15-2014, 09:00 AM   #32
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
OK, put in my 4 stage charger this past weekend....batteries have been on it charging for 48 hours....checked the output voltage from the converter...started off originally at 14.79v...now down to 13.2v if I recall.....
I took the batteries out of the coach - tested them with my meter...one was at 13.0, one at 13.02 volts, but that was just after disconnecting...I am going to let them sit for a few hours then recheck them...then have them load tested up the road....
I really figured that if these batteries did not have bad cells, that 2 days of charging on the new converter (I use 15amp extension cord to the trailer from my house) that it would charged up much higher volts?
Old 10-15-2014, 09:25 AM   #33
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
A good 12 volt battery with 100% charge should read about 12.7 VDC. Initial reading after charging may be higher, as in your case. Read the voltage 1-2 hours after removal of charge.
There's an excellent State of Charge chart floating around the forum somewhere.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-15-2014, 09:42 AM   #34
lewster's Avatar
Naples, FL , Hood River, OR
Actually, some batteries read at 12.8-13.2,VDC when fully charged. For example, Lifelines at 12.7 VDC are considered 10% discharged. All depends on the specifications of the battery manufacturer.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-15-2014, 11:40 AM   #35
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Now reads 12.95 and 12.97
Old 10-15-2014, 11:41 AM   #36
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I hope this men's they are A-OK
Old 10-15-2014, 12:49 PM   #37
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would be comfortable with the batteries being 'ok'..
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-15-2014, 01:14 PM   #38
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I will have them tested at the advanced auto up the road as a final check as I already have them out just as a final check
Then I just cruise on
Can someone tell me what to expect with use in boondocking? How many amp hours do I have and is there a way I can just check the voltage like this at the battery and have a more accurate sense of how much charge I have left?
Old 10-15-2014, 01:54 PM   #39
1981 31' Excella II
New Market , Alabama
If you had an amp probe or just a simple amp meter in series with a battery you can put a load on it and measure the voltage of the battery. When it gets below say 11V I would say it is done. Find a known constant load like a a fan motor etc and just let it run till the battery is dead. You can calculate the amp hours by multiplying the load amp by the time in hours. 2 A for 24 hrs is 48 AHr. The problem is figuring out when the voltage drops below 11V. If I were doing this at work I would use a data logger of some sort to measure all this and graph it and record the data to a file. You will find some load curves of batteries online. The more current you draw, the less amp hours you will get from a battery. You can make your own standard test and do it about once a year to see if your batteries are up to snuff. It is not something I would do often since deep cycling the batteries uses them up.
Perry
Old 10-15-2014, 01:58 PM   #40
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Name:	ImageUploadedByAirstream Forums1413403036.898586.jpg
Old 10-15-2014, 01:59 PM   #41
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
You should be able to download a spec sheet for your battery from the manufacturer...
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 10-15-2014, 02:11 PM   #42
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
GOOD BATTERIES!!
But you don't know the whole story..
One way to 'check' your systems... but not the only one... based upon your ticket above, you have over 500 AMPs...here is yet another link to 'convert' watts/amps/volts... How to Convert Watts to Amps Simplified -- Converting Amps to Watts the easy way
So, using 500 AMPS x 12Volts = 6000 watts.
If you put an 'ammeter' in the circuit, you can read the loads easier.. but, doing the 'test at load' as mentioned below will give you a 'ballpark' of your capability and longevity on the batteries and YOUR system.
Before you head out... for a "test".. start up all the 12V goodies... check voltage when all 'load' is on the batteries... run for an hour... check voltage.... repeat for 6 hours. Compare the voltages at each hour.. When you go 'boon docking', check voltages every couple of hours.. I bet you will find the voltages hold up pretty well...unless you are running extra loads like the heater.
Channing
WBCCI# 30676
Who's Thirsty???? Bluemoon64 Off Topic Forum 6 11-27-2013 06:42 AM
Cell Phone for full timer Gunnyusmc Full-Timing 79 02-16-2008 08:12 AM
Mucho Gusto - New Member South of the Border IzZihua Member Introductions 0 07-15-2006 12:55 AM
Cell phone provider question (T Mobile) yargseth Electrical - Systems, Generators, Batteries & Solar 20 04-10-2004 06:39 PM
Best cell service in Texas State Parks? JeffandSuzanne Our Community 14 02-20-2004 09:39 AM
