Echoing earlier good comments --
Overfilling with distilled water was likely not a lasting problem. Specific gravity testing with hydrometer advisable.
Are you sure that the batteries were fully charged before you did your voltage testing? I would plug the trailer into shore power for a couple of days, then unplug, wait an hour, and test the voltage again. If it drops down to 12.4 right away (or lower), I would take the batteries into an Interstate store for testing, and ask for replacements under your warranty. Call the dealer also IMO.
Are you sure all your 12-volt loads are off after you unplug from shore power? Other than the propane detector, check for:
hidden storage compartment lights
stereo/radio/sub-woofers hidden
fridge humidity control switch
fridge off
inverter off and no 120 volt loads
etc.
Different AS models have various phantom loads, such as these.
Good luck!
Peter
