| want to order new converter
I have started to order a converter a couple times. Playing a little phone-tag with Best Converter. Thought I should take a moment first, before phoning him back, to understand what I HAVE....
I took a picture of the inside my electrical compartment. I have verified that my old Univolt is g-o-n-e. It was replaced with a battery charger and there is a receptacle box which it can be plugged into. The charger is hard wired to a *spare set* of terminals on the battery (separate from the main pos/neg cables).
Attached is a pic of the fuse panel. I know, it's a mess. Can you tell if this is the original panel? It looks like a panel has been secured to a roughly cut plywood base. I don't have any idea what the original panel looked like ... There is also a box at the wall, inside a bathroom cabinet, with two circuit breakers. It looks pristine.
So, do I need any more info before calling Randy back?
Laura
