Old 01-16-2010, 07:35 PM   #1
Maniacal Engineer
barts's Avatar
Menlo Park , California
Want to move batteries.... but where to run the wires?
I'm starting to get our new (to us) 1971 Tradewind's systems working... among other things I added a circuit breaker to the battery line today so I could replace the hard-to-find main fuse w/ some 1/4" copper tubing safely.... but I sure would like to get the batteries relocated from underneath the bed (sans battery box!) to the tongue. I've worked out how to weld up a removable platform to hold the batteries there, but running the needed #6 wire cleanly back to the Univolt looks... tricky. Am I going to have to remove the belly pan? Or is there some handy way of not doing that? It's clear from the corrosion and missing fastener holes in the pan that that the belly pan removal will have to happens sooner or later, but later sound better right now .
Thanks -
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 01-17-2010, 08:31 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Drop the belly pan. I know you don't want to. You can then run the wire in the frame channel and out the tongue. You can also inspect he frame for any issues.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-17-2010, 09:03 AM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
when going up front with your batteries, I seriously look at using #4 gauge wire, minimum...and solder the copper cable ends for the best conductivity, as well...
Ray
Ray & Pat; Morada, CA
If you could move 76sovereign Fun & Games 5 06-30-2009 04:41 PM
Oh no it wont move!! Angel73 Fresh Water Systems 9 03-17-2007 09:56 AM
Move Over! overlander63 On The Road... 5 07-23-2004 09:58 AM
