Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 05-15-2008, 01:20 PM   #1
dbaur
Profile:  1969 21' Globetrotter
Gray , Maine
Vital Signs for Power Converter
We bought an Intelli-Power PD9130 30 amp power converter two years ago for our 1969 GT. After fully charging the battery this Spring, I am getting no power to the AS. When I hook into AC everyting works fine. The battery tests out fine and none of the fuses are blown. Could the power converter be bad? Any thoughts on how I can check it? Thanks for any help on this. Dave
dbaur is offline   Reply With Quote
Old 05-16-2008, 06:06 AM   #2
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
When you are not on shore power the converter does nothing. Power is routed to the trailer from the battery through the 12 volt distribution panel. I would check the cables from the battery. The connection to the frame of the trailer from the negative post would be a good place to start.
Richard
Charter Member Four Corners Unit
Old 05-16-2008, 11:47 AM   #3
dbaur
Gray , Maine
Converter
Thank you. That makes perfect sense. Appreciate the help. Dave
Old 05-16-2008, 06:51 PM   #4
dbaur
Gray , Maine
converter
Thank you, Richard. You pointed me in the right direction. Problem ended up being faulty battery cable connectors. Thanks again, Dave
wiring of new power converter Joe1261 Batteries, Univolts, Converters & Inverters 1 03-21-2007 08:13 PM
Power Converter Died??!! JimGolden Electrical - Systems, Generators, Batteries & Solar 5 11-17-2005 07:18 PM
Begging for some help here with power converter sunshine sam Vintage Kin 8 09-29-2005 08:19 AM
New Power Converter 66 Tradewind Batteries, Univolts, Converters & Inverters 9 05-25-2005 04:33 AM
Power Converter? Maediris73 Batteries, Univolts, Converters & Inverters 1 05-17-2005 08:14 PM
