Originally Posted by BambiTex
1. Should I connect the new Shore Power receptacle green wire to my frame?
Yes, that is what is done in new trailers, in essence. The accepted practice is to run the green wire to the ground bar in the panel, and also run a wire from the ground bar in the panel to the frame. Your old fuse box probably doesn't have enough room for a ground bar, and no harm is done by grounding the frame.
2. Will the GFCI in my garage trip?
Only if there is a short between neutral and the frame. It is possible that something like that was done deliberately, and also possible that it was done accidentally. If you get nuisance trips, you should find the short and fix it.
3. If I replace two prong outlets with three prong should they be GFCI outlets?
If it were my trailer I would leave the two prong outlets, and instead upgrade the fuse box to a breaker panel with GFCI breakers for the circuits that serve outlet strings.
You may find that GFCI outlets will not fit.
4. Should I ground the new outlets to the frame?
There's no good answer, which is why I wouldn't use 3 prong outlets unless I had also rewired so that a reliable ground is available.
It's pretty unusual to need a 3 prong outlet while camping. For a while I had a space heater with a metal chassis that required one, and I rented the "rug doctor" once and used it in my trailer, which required one. The usual things, toasters, laptops, phone chargers, holiday lights, hair dryers, don't use it.
5. In the interim, should I ground appliances like the electric water heater?
No good answer. 1950s wiring practice was to bond major stationary appliances to the frame or (copper) plumbing, or connect them using armored cable (BX), which sort of grounded them but not really.
