Old 05-10-2019, 05:06 PM   #1
1972 23' Safari
Middletown , Rhode Island
Victron MPPT grounding wire size?
Anyone know whatís the smallest size wire I can use to ground my Victron 100/30 MPPT controller to my chassis?
Mx468 is offline   Reply With Quote
Old 05-10-2019, 05:44 PM   #2
2018 25' Flying Cloud
Portland , Oregon
Normally you wouldnít ground it to the chassis but take the negative back to the bus bar at a central location. Thatís to avoid ground loops.
Depending on the distance, 8-10 ga wire would be my first choice settling for 12 ga if really necessary and you have less than 400w of solar panels.
daleyocum is offline   Reply With Quote
Old 05-10-2019, 06:21 PM   #3
Fort Davis , Texas
I think he is referring to the chassis ground for the controller. It has nothing to do with the DC negative.
Pat
pdavitt is offline   Reply With Quote
Old 05-10-2019, 10:04 PM   #4
Portland , Oregon
Pat
If thatís whatís being asked the unitís case CAN be grounded but doesnít need to be as far as I can tell. Mine isnít. The case isnít connected to the negative terminals of the unit.
Old 05-11-2019, 07:35 AM   #5
Fort Davis , Texas
I've got an 8AWG ground wire running from the chassis ground stud on my Smart Solar 150/45 charge controller (48V Battery System) directly to the vehicle chassis ground point. I've found it is always prudent to give those pesky electrons some place to go if an electrical fault occurs in the device.
Just like I have a 2/0AWG ground wire running from my Quattro 48/5000 directly to the vehicle chassis ground stud. ABYC requires that the inverter/charger chassis ground wire be the same size as the DC Positive wire.
I almost got fried once by a device that did not have a proper chassis ground. Guess I am a little paranoid in this regard.
Pat
Old 05-11-2019, 08:36 AM   #6
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
In NEMA code ground wires can be down sized one size for anything 10ga and larger. So with that said. 12 ga wire will be plenty for a simple frame ground for your charger.
Dept of ďOverKillĒ
GMFL is online now   Reply With Quote
Old 05-11-2019, 08:55 AM   #7
2012 Avenue Coach
Corpus Christi , Texas
deletedgkjofd;ijgdfgdfd
rowiebowie is offline   Reply With Quote
Old 05-22-2019, 01:59 PM   #8
2018 19' Tommy Bahama
MERCER ISLAND , WA
Solar Controller Upgrade
I am looking to upgrade the factory installed Adkinson solar controller to a SmartSolar MPPT 100/20 and have a wiring question. The Adkinson has a positive and negative wire from battery and a positive from the panel. If installing the MPPT controller would the negative panel connection on the contoller run to the negative bus bar? I have not yet investigated where the negative panel wire is terminated. Thanks.
johnnycla is offline   Reply With Quote
Old 05-22-2019, 11:57 PM   #9
Portland , Oregon
On my 2018 FC25 the two wires from the panel, green and yellow, have small labels on them saying ďsolarĒ and come down where all the DC electrical stuff is collected and near where the controller is located. My GUESS is your panels do the same but the green negative wire is grounded nearby.
Connecting Victron MPPT and BMV marter Generators & Solar Power 15 01-08-2019 12:40 PM
Swap out Atkinson charge controller for Victron MPPT mdtravelers Electrical - Systems, Generators, Batteries & Solar 16 11-18-2018 02:15 PM
android app can see replaced victron MPPT system waninae39 Electrical - Systems, Generators, Batteries & Solar 1 07-16-2018 07:13 PM
Victron MPPT Mounting uncle_bob Generators & Solar Power 7 05-27-2018 03:50 PM
One Wire Running Lights---Effects on Grounding tinbender Lights - Interior & Exterior 7 04-18-2011 07:22 AM
