Old 04-05-2018, 06:41 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Victron: control head
I have the following victron items
Cyrix- battery isolator
Shunt and BMV702 Btooth monitor
BP-100 battery protect
MPP solar controller 100/30
i did not want to add a separate status/control monitor for each as i only have so much free wall space
so I found "Color Control GX" on sale on ebay NEW
much better price than a local dealer or amazon
The Color Control (CCGX) provides intuitive control and monitoring for all Victron power systems. The list of Victron products that can be connected is endless: Inverters, Multis, Quattros, MPPT solar chargers, BMV battery monitors, Lynx Ion + Shunt and more
Name:	lictron control gx.jpg
waninae39 is offline   Reply With Quote
Old 04-05-2018, 06:57 PM   #2
2011 22' Sport
Portland , Oregon
Did you buy the BMV-702 or BMV-712? The BMV-712 is the newer model with built-in Bluetooth, the BMV-702 requires adding a Bluetooth dongle to enable it for BT.
Have you planned out how you are going to integrate all of this together? How are you planning to integrate the BP-100? As a low voltage disconnect? Why not just rely on the one built into the BattleBorn?
There was a discussion not long ago on the CCGX, if you didn't see it: http://www.airforums.com/forums/f449...rs-161855.html
SilverHouseDreams is offline   Reply With Quote
Old 04-05-2018, 09:06 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
yes, i have the BMV-712 with btooth, typo on my part
Old 04-05-2018, 09:07 PM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
this is the rear of the CCGX
Name:	rear of ccgx.JPG
Old 11-11-2018, 10:40 AM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i mounted my monitoring devices above the fridge in my sport 22FB
They are all mounted on a 1/4" plywood board, i made a small 1" frame around to hide the wires
i also beveled the bottom so that the bottom face is on an angle and so that the top edge can touch the wall, that way i can place 3M VHB tape on the bottom edge and the upper edge to keep the panel solidly in place
the various wire either go:
  • down , to access ac power
  • left , signal cables and cat5 wires that go through the pantry and under the whole kitchen area to head towards all the power electronics under the bed road side
  • up to access DC supply from the AV centre
Name:	monitoring tools above fridge-with annotations.jpg
Old 11-12-2018, 03:53 PM   #6
waninae39's Avatar
2017 22' Sport
NCR , Ontario
to prepare for winter
i removed the BB LION battery
and reinstalled the factory Lead acid
i also reprogrammed the BMV712
here are the proper summer Lion setting
the only changes i made for lead acid were
  • peukert 1.25
  • charge efficiency 95%
if anyone knows of any other changes i should make to maintain the system with Lead acid battery , please post here
Name:	bmv712-lion setting.JPG
Old 11-12-2018, 05:29 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you are going to keep all of the "smarts" running through the winter, you should keep the trailer on some sort of power source.
Ideally for a lead acid in cold weather, you would want a temperature sensor on the battery and a feed back into the charge system.
Old 11-12-2018, 05:50 PM   #8
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Hi Bob
it is is on ext ac power
i did not want to run ext ac without a battery
as i am not keeping heat inside, it did the plow out followed by antifreeze in the traps
i want to do some work over the winter , thus want to maintain the system operating, s once the cold is gone in the spring, the BB lion goes back in
thus i am now asking for BMV 712 battrey settings for the lead acid battery
Old 11-13-2018, 05:51 AM   #9
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
That's interesting...
One of the reasons I got the BB's is so I wouldn't have to remove for Winter storage.
I guess I just understand the same things differently. 😂
No drop, steady since put in storage.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 11-13-2018, 08:43 AM   #10
waninae39's Avatar
2017 22' Sport
NCR , Ontario
@Robert
where are you that you can leave the BB LION in the AS.
in my area, its too cold ie < 0C
Old 11-13-2018, 08:45 AM   #11
Half a Rivet Short
Originally Posted by waninae39 View Post
Hi Bob
Hi
Spend the extra couple bucks on the temperature sensor and patch it into the system. Then set the charger up to use the temperature information. Since there are two sensors and two ways to integrate them this becomes a "that depends" kind of thing. Once goes on the 712 and gets set up there. The other can go into the control head or into the Multi Plus and gets set up accordingly.
The same "it's too cold" (as in < 0F, 0C fine for BB's ... yes, I've been in Ottawa in the winter ...) thing applies to battery charging. Keeping things lined up properly is important. A totally dead battery at 0F looks a lot like a fully charged battery at 70F.
Old 11-13-2018, 08:48 AM   #12
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i do have both temp sensors
one on the bmv712
the other on the mutiplus
Old 11-13-2018, 09:30 AM   #13
@Robert
WNY, you can't charge, you can leave.
Amanamus
"Tahawus"
Old 11-14-2018, 07:25 AM   #14
Half a Rivet Short
one on the bmv712
Hi
Ok, then you should (as part of changing the settings) make sure that temperature compensation *is* enabled. For many lithium setups, you disable temperature compensation.
Which Victron remote control or monitors? fran&frank Batteries, Univolts, Converters & Inverters 23 04-05-2018 09:18 PM
Victron Battery Monitor Install NoResults Batteries, Univolts, Converters & Inverters 82 01-23-2017 10:02 AM
Victron 702 Placement stephenb Electrical - Systems, Generators, Batteries & Solar 8 09-13-2016 11:33 AM
Victron Battery Monitor with Bluetooth connection to smart phone jhart657 Electrical - Systems, Generators, Batteries & Solar 23 07-27-2016 01:56 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
